scsiblade.qosvioldetectregfail events
scsiblade.qosvioldetectregfail EMS events occur when the Quality-of-Service (QoS) subsystem fails to register for updates during initialization due to an internal error (e.g.
scsiblade.QoSViolDetectRegFail
- Severity
ERROR
- Description
This message occurs when the Quality-of-Service (QoS) subsystem fails to register for updates during initialization due to an internal error (e.g. there is not enough system memory available). As a result, workloads might not meet their minimum throughput or their service-level objectives (SLOs).
- Corrective Action
The registration will continue to be retried. If this message continues to occur, perform a planned takeover/giveback sequence to reset the reporting node nondisruptively by using the "takeover -ofnode (reporting_node)" and "giveback -ofnode (reporting_node)" commands. If the problem persists, contact Contact NetApp technical support.
- Syslog Message
Failed to register for violation detection updates. QoS min-throughput might operate in a limited capacity.
- Parameters
errorCode (INT): Error code that was returned during registration.
