ONTAP EMS reference
security.cluster events
security.cluster EMS events occur when ONTAP encounters issues associated with cluster-network security certificates.
security.cluster.network.cert.expired
Severity
ERROR
This message occurs when a digital certificate associated with a node for cluster-network security is already expired. Cluster-network communication will be disrupted.
Corrective Action
Update the node certificate with a valid CA-signed certificate using the 'security cluster-network certificate modify' command.
Syslog Message
A digital certificate associated with cluster-network security for the Node %s with Certificate Name %s, Certificate UUID %s and Certificate Authority '%s' has already expired.
node (STRING): Name of the Node associated with this certificate.
cert_name (STRING): Name of the digital certificate that is about to expire.
uuid (STRING): UUID of the digital certificate under certificate manager.
certificate_authority (STRING): Name of the Certificate Authority whose digital certificate that is about to expire.
security.cluster.network.cert.expiring
Severity
ERROR
This message occurs when a digital certificate associated with a node for cluster-network security is about to expire. Cluster-network communication will be disrupted if the certificate expires.
Corrective Action
Syslog Message
A digital certificate associated with cluster-network security for the Node %s with Certificate Name %s, Certificate UUID %s and Certificate Authority '%s' will expire in %d day(s).
days (INT): Number of days remaining until the certificate expires.
