sis.upgrade events
sis.upgrade EMS events occur when ONTAP encounters issues associated with Single Instance Storage (SIS) upgrades.
sis.upgrade.aggr.metafile.failed
- Severity
ERROR
- Description
This message occurs when Single Instance Storage (SIS) metafiles cannot be created in the aggregate containing the volume, during a Data ONTAP® upgrade. The aggregate might be full. The 'sis status' command will not display this volume. SIS operations cannot be triggered manually or according to a schedule for the volume.
- Corrective Action
Ensure that space is available in the aggregate containing the volume. After correcting the underlying issue indicated by the error message, remount the volume for the SIS upgrade to be triggered again. If the upgrade succeeds, SIS then resumes normally.
- Syslog Message
Could not create the metafiles for the volume %s%s : %s.
- Parameters
volname (STRING): Volume name.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
err (STRING): Reason for the failure.
sis.upgrade.feature.enable
- Severity
NOTICE
- Description
This message occurs during upgrade to Data ONTAP® 9.2 or later, when we start enabling Volume Efficiency features on the existing compatible volumes on All-Flash Optimized nodes in the background.
- Corrective Action
(None).
- Syslog Message
Volume efficiency features will be enabled on Volumes of All-Flash Optimized nodes in the Cluster.
- Parameters
(None).
sis.upgrade.feature.enable.done
- Severity
NOTICE
- Description
This message occurs during upgrade to Data ONTAP® 9.2 or later, when we have completed enabling the Volume Efficiency features on the existing compatible volumes.
- Corrective Action
(None).
- Syslog Message
Volume efficiency features were enabled on Volumes of All-Flash Optimized nodes in the Cluster.
- Parameters
(None).
sis.upgrade.feature.enable.fail
- Severity
INFORMATIONAL
- Description
This message occurs during upgrade to Data ONTAP® 9.2 or later, when we fail to enable Volume Efficiency features on the existing compatible volume on All-Flash Optimized nodes.
- Corrective Action
Manually try enabling the Volume Efficiency features on the volume using the "volume efficiency modify" command.
- Syslog Message
Could not enable Volume Efficiency features for Volume %s of vserver %s.%s
- Parameters
volume (STRING): Volume name.
vserver (STRING): Vserver name.
reason (STRING): Reason for failure.
sis.upgrade.feature.enabled
- Severity
INFORMATIONAL
- Description
This message occurs during upgrade to Data ONTAP® 9.2 or later, when we enable Volume Efficiency features on the existing compatible volume on All-Flash Optimized nodes.
- Corrective Action
(None).
- Syslog Message
Volume Efficiency features enabled on Volume %s of Vserver %s.
- Parameters
