ONTAP EMS reference
sk.long events
sk.long EMS events occur when ONTAP encounters issues associated with SK process message processing.
sk.long.queued.msg
Severity
NOTICE
This message occurs when an SK process detects that a message has been queued longer than expected, as defined by an internal threshold. System features and performance are not affected.
Corrective Action
(None).
Syslog Message
"%s" started processing a long queued message: "%s" queued %lu ms.
procname (STRING): The name of the SK process.
message_type (STRING): The message type.
queue_time (LONGINT): Message queued duration, in milliseconds.
threshold (LONGINT): Message queued threshold, in milliseconds.
sk.long.running.msg
Severity
NOTICE
This message occurs when an SK process has finished processing a message that took longer than expected, as defined by an internal threshold.
Corrective Action
(None).
Syslog Message
"%s" finished processing a long running message: "%s" took %lu ms.
duration (LONGINT): Message processing duration, in milliseconds.
threshold (LONGINT): Message processing threshold, in milliseconds.
