spm.mntsvc events
spm.mntsvc EMS events occur when the Node Root Mount Service (mntsvc) involuntarily terminates.
spm.mntsvc.process.exit
- Severity
ALERT
- Description
This message occurs when the Node Root Mount Service (mntsvc) involuntarily terminates. The termination of this service affects all Remote Support Agent services provided by the node.
- Corrective Action
The system attempts to recover by restarting the process. If the process does not restart within the threshold number of retries, then an AutoSupport message is sent. If your system is not configured to send AutoSupport messages and the issue persists, contact technical support.
- Syslog Message
The Node Root Mount Service (mntsvc) with ID %d exited as a result of %s. This server will attempt to restart.
- Parameters
id (INT): Process identifier.
cause (STRING): Plain text description of why the process exited.
