ONTAP EMS reference
tsse.scan events
tsse.scan EMS events occur when ONTAP encounters issues associated with inactive data compression and garbage collection scan operations.
tsse.scan.catalog.failed
Deprecated
Deprecated as of version 9.13.1.
Severity
ERROR
This message occurs when inactive data compression scan related information failed to be updated on the catalog file.
Corrective Action
(None).
Syslog Message
Cold Data Scan catalog update failed on '%s' - %s.
vol (STRING): Volume name.
fail_message (STRING): Update failure reason.
tsse.scan.catalog.updated
Deprecated
Severity
NOTICE
This message occurs when inactive data compression scan related information updated on the catalog file.
Corrective Action
(None).
Syslog Message
Cold Data Scan catalog updated on '%s' (SE ratio local: %s, SE ratio migrate: %s, Incompressible: %llu%%, Hot data: %llu%%, Mode: %d, SE ratio cold migrate: %s).
se_ratio_local (STRING): SE Ratio for local reporting.
se_ratio_migrate (STRING): SE Ratio for migrate reporting.
incomp_data_pct (LONGINT): Incompressible data percentage.
hot_data_pct (LONGINT): Hot data percentage.
scan_mode (INT): Scan mode.
se_ratio_cold_migrate (STRING): SE Ratio for Cold migrate reporting.
tsse.scan.start.failed
Severity
NOTICE
This message occurs when either inactive data compression or garbage collect or garbage collect reclamation Scan fails to start.
Corrective Action
(None).
Syslog Message
'%s' failed to start on '%s' - %s.
scan_type (STRING): Scan type.
vol (STRING): Volume or aggregate name.
fail_message (STRING): Scan failure reason.
