ONTAP EMS reference
wafl.trans events
wafl.trans EMS events occur when the system transitions a hybrid aggregate from 7-Mode to clustered Data ONTAP.
wafl.trans.ssd.cache.disable
Severity
NOTICE
This message occurs when the system transitions a hybrid aggregate from 7-Mode to clustered Data ONTAP. As part of transition, SSD caching is disabled until the transition is committed.
Corrective Action
No action is required. After the transition operation is committed, SSD caching is automatically reenabled.
Syslog Message
SSD caching on hybrid aggregate "%s" has been disabled because a transition operation is in the pre-commit phase.
name (STRING): Aggregate name.
