asup.dcn events
asup.dcn EMS events occur when ONTAP encounters issues associated with AutoSupport configuration propagation to data compute nodes and the AI Data Engine cluster.
asup.dcn.sync.failed
- Severity
NOTICE
- Description
This message occurs when the AutoSupport configurations in the ONTAP cluster fail to propagate to the data compute nodes and the AI Data Engine cluster. The system will automatically retry the propagation in the background using exponentially increasing intervals until it is successful.
- Corrective Action
(None).
- Syslog Message
AutoSupport configurations failed to propagate to data compute nodes and AI Data Engine cluster. Error: %s
- Parameters
FailureReason (STRING): Sync failure reason.
asup.dcn.sync.success
- Severity
NOTICE
- Description
This message occurs when the AutoSupport configurations in the ONTAP cluster have successfully propagated to the data compute nodes and the AI Data Engine cluster after a previous failure.
- Corrective Action
(None).
- Syslog Message
AutoSupport configurations successfully propagated to data compute nodes and AI Data Engine cluster.
- Parameters
(None).
