azurearc.himds events
azurearc.himds EMS events occur when ONTAP encounters issues associated with the Hybrid Instance Metadata service (HIMDS) startup.
azurearc.himds.startup.failed
- Severity
ERROR
- Description
This message occurs when the Hybrid Instance Metadata service (HIMDS) failed to start up at boot time. The Microsoft Connected Machine Agent will not be able to listen for connections. This message is only applicable to Azure NetApp Files systems.
- Corrective Action
Look at the logs in /var/opt/azcmagent/log/himds.log for more information. Reboot the machine. If this does not resolve the issue, contact NetApp technical support.
- Syslog Message
The Hybrid Instance Metadata service (HIMDS) failed to start.
- Parameters
(None).
azurearc.himds.startup.success
- Severity
NOTICE
- Description
This message occurs when the Hybrid Instance Metadata service (HIMDS) starts up successfully and is listening for connections. This message is only applicable to Azure NetApp Files systems.
- Corrective Action
(None).
- Syslog Message
The Hybrid Instance Metadata service (HIMDS) started successfully.
- Parameters
(None).
