ONTAP EMS reference
cf.cdo events
cf.cdo EMS events occur when ONTAP encounters issues associated with disk operations over the High Availability (HA) interconnect.
cf.cdo.badMsg
Severity
ERROR
This event is issued when the filer receives a disk operation message over the High Availability (HA) interconnect that it does not recognize. This is likely due to a change in the message protocol that the down-revision partner does not recognize. Fix this problem by upgrading the partner to a compatible version of Data ONTAP®. This message is not emitted for every message received to avoid spamming the console.
Corrective Action
Upgrade both nodes to the same release.
Syslog Message
unknown message %d received from partner (%d unknown messages since boot).
msg (INT): Message which was not known.
count (INT): Number of unknown messages.
cf.cdo.reportOp
Severity
NOTICE
This event is issued when the filer bypasses or unbypasses a disk after being requested to do so by its partner. The bypassing of a drive on a particular port may only be done by the host which is attached to that port; the High Availability (HA) software ensures that both ports of the drive are bypassed by communicating bypass requests to the partner.
Corrective Action
(None).
Syslog Message
%s disk %s on behalf of the partner.
op (STRING): Operation description
driveName (STRING): Drive name
