ONTAP EMS reference
cf.partner events
cf.partner EMS events occur when ONTAP encounters issues associated with HA partner operations.
cf.partner.login
Severity
INFORMATIONAL
This event is issued when a login to the console of the partner occurs as a result of the 'partner' command being issued with no arguments.
Corrective Action
(None).
Syslog Message
Login to partner shell: %s
hostname (STRING): The name of this node
cf.partner.logoff
Severity
INFORMATIONAL
This event is issued when a logoff from the console of the partner occurs as a result of the 'partner' command being issued with no arguments.
Corrective Action
(None).
Syslog Message
Logoff from partner shell: %s
cf.partner.nvram.notSync
Severity
INFORMATIONAL
This message occurs during takeover, when the system finds the partner nonvolatile memory (NVRAM) unsynchronized. There might be data loss.
Corrective Action
(None).
Syslog Message
Partner NVRAM was not synchronized. Some data might be lost.
(None).
cf.partner.nvram.state
Severity
INFORMATIONAL
This message occurs during takeover, when the system determines that the partner mailbox is stale. This might mean that partner nonvolatile memory (NVRAM) is unsynchronized and might have some data loss.
Corrective Action
(None).
Syslog Message
Partner mailbox was stale. Partner NVRAM might not be synchronized and some data might be lost.
(None).
cf.partner.ready.giveback
Severity
INFORMATIONAL
This message occurs when the partner is booted and ready for giveback.
Corrective Action
Verify that network connectivity is restored, and then use the "storage failover giveback" command to initiate giveback to the partner.
Syslog Message
Partner is booted and ready for giveback.
(None).
cf.partner.shortUptime
Severity
ERROR
This message occurs when a node in a controller failover pair determines that the partner node has stayed up for a very short time period. This might result in a takeover
Corrective Action
Check the disk connectivity to the partner node. If the problem persists and the partner node restarts multiple times, perform hardware diagnostics in maintenance mode, and then consult the EMS logs to determine why this is happening.
Syslog Message
Partner up for %llu seconds only.
seconds (LONGINT): Time duration for which the partner was up.
