de.job events
de.job EMS events occur when a job in AIDP fails to complete successfully.
de.job.failure
- Severity
ERROR
- Description
This message occurs when a job in AIDP fails to complete successfully. An EMS event will be logged every time a job moves to failure state.
- Corrective Action
Check the description of the job that has failed and retry the workflow if necessary. For example, if the workspace creation job failed, check which sub-job or task caused the failure and retry the workflow. The following API shows all details of the job - /data-engine/jobs/{uuid} where uuid is jobId param.
- Syslog Message
Job failure event for AIDP with id: %s, owner: %s, description: %s, user/group: %s, severity: %s, createTime: %s, resource UUID: %s, resource name: %s, resource type: %s, job ID: %s, job name: %s, job type: %s, job state: %s
- Parameters
id (STRING): Event ID of the job failure event.
owner (STRING): Owner of the event.
description (STRING): Description of the job failure event.
userOrGroup (STRING): User or group that owns the job failure event.
severity (STRING): Severity of the event.
createTime (STRING): Creation time.
resourceUUID (STRING): ID of the resource - workspace, data collection, policy ID etc.
resourceName (STRING): Name of the resource.
resourceType (STRING): Resource type of the event - workspace, data collection, policy etc.
jobId (STRING): Job ID of the job that failed.
jobName (STRING): Name of the job that failed.
jobType (STRING): Job type of the job that failed.
jobState (STRING): Job state of the job that failed.
attributes (STRING): Dynamic attributes related to the job failure event. It can be anything like size, space, usage etc.
visibility (STRING): To whom the event is visible.
