ONTAP EMS reference
flexcache.svmdr events
flexcache.svmdr EMS events occur when ONTAP encounters issues associated with FlexCache volume SVM disaster recovery (SVM-DR) notifications.
flexcache.svmdr.ecv.warn
Severity
ERROR
This message occurs when FlexCache volumes residing on a cluster are not notified about origin vserver going through SVMDR FO/FB events because ECV of FlexCache cluster is less than 9.18.1.
Corrective Action
Update the cluster version of %s to 9.18.1 or above.
Syslog Message
ECV of FlexCache cluster(%s) is not eligible to receive notifications related to origin vserver %s going through SVMDR FO/FB events.
clusterName (STRING): Name of the cluster hosting the FlexCache volume.
originVserver (STRING): Name of the Origin Vserver.
flexcache.svmdr.notification.clus.failed
Severity
ERROR
This message occurs when FlexCache volumes residing on a cluster are not notified about origin vserver going through SVMDR FO/FB events.
Corrective Action
Use the 'volume flexcache origin svmdr-origin-refresh' command to update the origin details for given FlexCache vserver and FlexCache volume.
Syslog Message
FlexCache SVM_DR notification call has failed for FlexCache cluster %s, Origin Vserver:%s. Error: %s.
errorString (STRING): Error string.
flexcache.svmdr.notification.failed
Severity
ERROR
This error message occurs when the SVM-DR operation for the FlexCache volume fails.
Corrective Action
Syslog Message
FlexCache SVM_DR notification call has failed for FlexCache cluster %s, FlexCache Vserver:%s, FlexCache Volume:%s. Error: %s.
cacheVserver (STRING): Name of the Vserver hosting the FlexCache volume.
cacheVolName (STRING): Name of the FlexCache volume.
