ONTAP EMS reference
fp.est events
fp.est EMS events occur when ONTAP encounters issues associated with volume footprint estimator scan operations.
fp.est.scan.catalog.failed
Severity
ERROR
This message occurs when the volume footprint estimator scan fails to update the catalog file. This can cause footprint data reduction to be unreported post volume remount until the next scan updates the file.
Corrective Action
Check if there is atleast 4K worth of space available for the catalog metafile in the volume. Use "df <vol-name>" command to see available space details.
Syslog Message
Volume footprint estimator scan catalog update fails on "%s" - %s.
vol (STRING): Volume name.
fail_message (STRING): Update failure reason.
fp.est.scan.catalog.updated
Severity
NOTICE
This message occurs when related information of the volume footprint estimator scan is updated on the catalog file.
Corrective Action
(None).
Syslog Message
Volume footprint estimator scan catalog updated on '%s' (SE ratio local: %s, SE ratio migrate: %s, Incompressible: %d%%, Hot data: %llu%%, Mode: %d, SE ratio cold migrate: %s).
se_ratio_local (STRING): Storage efficiency ratio for local reporting.
se_ratio_migrate (STRING): Storage efficiency ratio for migrate reporting.
incomp_data_pct (INT): Incompressible data percentage.
hot_data_pct (LONGINT): Hot data percentage.
scan_mode (INT): Scan mode.
se_ratio_cold_migrate (STRING): Storage efficiency ratio for cold migrate reporting.
fp.est.scan.start.failed
Severity
ERROR
This message occurs when the volume footprint estimator scan fails to start. This might cause footprint data reduction reporting to be inaccurate. But the scan is expected to be triggered again in the next cycle which is likely to be the next day.
Corrective Action
Scan will be triggered again in the next cycle which is likely to be the next day.
Syslog Message
Volume footprint estimator scan fails to start on "%s" - %s.
fail_message (STRING): Scan failure reason.
fp.est.scan.vvol.gc.est.done
Severity
NOTICE
This message occurs when an attempt to estimate the space that can be reclaimed for the volume was completed successfully.
Corrective Action
(None).
Syslog Message
Volume footprint estimator scan completed on '%s' (Total Reclaimable blocks: %llu, Total garbage collection reclaimable blocks: %llu);
total_rclm_blks (LONGINT): Total physical blocks to be reclaimed in the volume.
total_gc_rclm_blks (LONGINT): Total physical blocks to be reclaimed by Garbage Collection on the volume.
total_repack_save_blks (LONGINT): Total physical blocks to be reclaimed by repacking on the volume.
gc_logical_pending_blks (LONGINT): Total logical blocks to be subjected for Garbage collection.
gc_physical_pending_blks (LONGINT): Total physical blocks to be freed by Garbage collection.
