ONTAP EMS reference
ic.linkwidthdegraded events
ic.linkwidthdegraded EMS events occur when the high-availability (HA) interconnect detects a degraded link width.
ic.linkWidthDegraded
Severity
ERROR
This message occurs when the high-availability (HA) interconnect detects a degraded link width. This can affect the write performance of the system.
Corrective Action
For externally connected links, make sure that the interconnect cables are connected properly and that small form-factor pluggable (SFP) modules, if applicable, are seated properly on both controllers. For internally connected links, disable and reenable the links one at a time by using the (privilege: advanced) "system ha interconnect link off" and "system ha interconnect link on" commands. If the problem persists, contact NetApp technical support.
Syslog Message
HA interconnect: Link width of link #%d degraded. Current: %dX, expected: %dX.
link_num (INT): Number that identifies the link.
link_width (INT): Current link width.
expected_width (INT): Link width expected for the HA interconnect type.
