ONTAP EMS reference
iscsi.loginfailure events
iscsi.loginfailure EMS events occur when an initiator fails an iSCSI login attempt.
iscsi.loginFailure
Severity
NOTICE
This event is issued when an initiator fails an iSCSI login attempt.
Corrective Action
Attempt to configure the iSCSI text keys on the initiator such that the iSCSI login succeeds. If the event occurs occasionally but does not affect stability or performance, no corrective action is needed but the event should be monitored. If the event persists and/or iSCSI application performance degrades, starting and stopping the iSCSI service and restarting any iSCSI applications may help clear the condition. Contact NetApp technical support.
Syslog Message
ISCSI: iSCSI login failure, '%s'
m (STRING): A more detailed message describing the iSCSI login failure.
