ONTAP EMS reference
kern.vm events
kern.vm EMS events occur when an attempt to create a new mapping in the virtual address space of a process has failed.
kern.vm.mmap.return
Severity
NOTICE
This message occurs when an attempt to create a new mapping in the virtual address space of a process has failed.
Corrective Action
(None).
Syslog Message
mmap(2) by %s (pid %d) for size %ld failed: %s, limit %ld, error %d.
process_name (STRING): Name of the process with the failed attempt.
process_id (INT): ID of the process with the failed attempt.
size (LONGINT): Size in bytes of the memory map attempt.
message (STRING): Details about the failed memory map attempt.
limit (LONGINT): Size in bytes of the process's virtual memory limit.
errno (INT): The error code returned to the process.
