lmgr.partner events
lmgr.partner EMS events occur when ONTAP encounters issues associated with partner node mirrored lock state synchronization.
lmgr.partner.locks.outOfSync
- Severity
ERROR
- Description
This message occurs when a partner node's mirrored lock state goes out of sync with the actual lock state.
- Corrective Action
Under normal conditions, no action is necessary. There is an automatic synchronize process that will attempt to resynchronize the lock state. You can wait for this process to synchronize the lock state, or you can manually resynchronize the lock state by running the 'debug locks mirrored sync' command in diag mode, with the Vserver, volume, and file ID supplied in this message.
- Syslog Message
Mirrored lock state is out of sync for %s%s/%s (DSID %08x) for file %d Snapshot copy %d (mirroring status %d communication status %d)
- Parameters
vol (STRING): Volume name.
app (STRING): Application UUID.
volident (STRING): Volume identifier to uniquely identify the volume in cases where the volume name alone is insufficient.
dsid (LONGINT): Data set identifier.
fileid (INT): File identifier.
snapid (INT): Snapshot(tm) copy in which the file exists, 0 for the active file system.
mirroring_status (INT): Error status from the mirroring operation.
csm_status (INT): Communication status from the mirroring operation.
lmgr.partner.locks.resynched
- Severity
INFORMATIONAL
- Description
This message occurs when a partner node's mirrored lock state is resynchronized with the actual lock state after having been out of sync previously.
- Corrective Action
The mirrored lock state is now synchronized between the partner nodes. You can verify the mirror state of the locks by running the 'debug locks mirrored show' command in diag mode, with the Vserver, volume, and file ID supplied in this message.
- Syslog Message
Mirrored lock state is now in sync for %s/%s (DSID %08x) for file %d Snapshot copy %d.
- Parameters
