ONTAP EMS reference
mcc.switchover events
mcc.switchover EMS events occur when a MetroCluster switchover operation finds a system metadata volume, used by config replication applications, in the nvfailed state.
mcc.switchover.mdvInNvfailedState
Severity
ERROR
This message occurs when a MetroCluster switchover operation finds a system metadata volume, used by config replication applications, in the nvfailed state.
Corrective Action
Verify the configuration.
Syslog Message
The 'in-nvfailed-state' was cleared on MetroCluster system metadata volume '%s'. The system will attempt to replicate all recent configuration updates (if any) to the local cluster. After the process completes, verify the configuration.
Volume (STRING): Volume
