ONTAP EMS reference
mgmtgwd.fg events
mgmtgwd.fg EMS events occur when ONTAP encounters issues associated with FlexGroup volume operations.
mgmtgwd.fg.32bit.nfs3ids
Severity
ERROR
This message occurs when the user creates a FlexGroup on a Vserver that has NFSv3 enabled, but uses 32-bit identifiers, which could cause file ID collisions.
Corrective Action
To prevent file ID collisions within the FlexGroup, enable NFSv3 64-bit FSIDs and file IDs on the Vserver. For more information or assistance, contact NetApp technical support.
Syslog Message
FlexGroup %s was created on Vserver %s which uses 32-bit NFSv3 FSIDs and File IDs. File ID collisions may occur.
volumeName (STRING): Name of the volume.
vserverName (STRING): Name of the Vserver.
mgmtgwd.fg.32bit.nfs4ids
Severity
ERROR
This message occurs when the user creates a FlexGroup on a Vserver that has NFSv4.x enabled, but uses 32-bit identifiers, which could cause file ID collisions.
Corrective Action
To prevent file ID collisions within the FlexGroup, enable NFSv4.x 64-bit FSIDs and file IDs on the Vserver. For more information or assistance, contact NetApp technical support.
Syslog Message
FlexGroup %s was created on Vserver %s which uses 32-bit NFSv4.x FSIDs and File IDs. File ID collisions may occur.
mgmtgwd.fg.modify.constituent.fail
Severity
ERROR
This message occurs when modification of a FlexGroup constituent's state fails during the operation to modify the state of the FlexGroup. The FlexGroup will be in the 'mixed' state and constituents that are still online will be able to serve data. Constituents that are offline will not be able to serve data. All management operations will be unavailable on the FlexGroup until it is brought completely online.
Corrective Action
Correct the problem based on the reason specified. If the error persists, contact NetApp technical support.
Syslog Message
Failed to modify the state of FlexGroup constituent %s in Vserver %s. Reason: %s.
volumeName (STRING): Name of the constituent.
reason (STRING): Reason for the failure.
mgmtgwd.fg.modify.rlbk.fail
Severity
ERROR
This message occurs after a series of failures. First, the FlexGroup resize fails. To recover, we try to rollback the FlexGroup constituents to their original sizes. If we fail to rollback any of these constituents, this message will occur.
Corrective Action
Syslog Message
Failed to rollback the size of FlexGroup constituent %s in Vserver %s Reason: %s.
mgmtgwd.fg.sis.op.constituent.fail
Severity
ERROR
This message occurs when the execution of the efficiency operation on a FlexGroup constituent fails.
Corrective Action
Correct the problem based on the reason specified. If the error persists, contact Netapp technical support for further assistance.
Syslog Message
Failed to execute the efficiency operation on FlexGroup constituent %s in Vserver %s. Operation: %s. Reason: %s.
operationType (STRING): Type of the efficiency operation.
