ONTAP EMS reference
mgwd.cluscheck events
mgwd.cluscheck EMS events occur when the system changes the cluster LIFs used for internal replicated database (RDB) operations, ensuring they are connected to different cluster switches for optimal cluster resiliency.
mgwd.cluscheck.rmtDevRepair
Severity
NOTICE
This message occurs when the system changes the cluster LIFs used for internal replicated database (RDB) operations, ensuring they are connected to different cluster switches for optimal cluster resiliency.
Corrective Action
(None).
Syslog Message
Cluster LIF "%s" with IP address %s connected to cluster switch "%s" is being replaced with cluster LIF "%s" with IP address %s connected to cluster switch "%s" in the RDB.
existinglif (STRING): Cluster LIF being replaced.
existingaddress (STRING): IP address of the cluster LIF that is being replaced.
existingremotedevice (STRING): Cluster switch connected to the home port of the IP address being replaced.
replacementlif (STRING): Cluster LIF being added.
replacementaddress (STRING): IP address of the cluster LIF that is being added.
replacementremotedevice (STRING): Cluster switch connected to the home port of the IP address being added.
