ONTAP EMS reference
monitor.chassistemperature events
monitor.chassistemperature EMS events occur when ONTAP encounters issues associated with chassis temperature monitoring.
monitor.chassisTemperature.cool
Severity
ALERT
This message occurs when the chassis temperature is too cool. This is a warning message.
Corrective Action
The appliance cannot function in an environment that is too cold; find ways to warm the appliance.
Syslog Message
Chassis temperature is too cool: %s
describe_toocool (STRING): Description of the condition.
monitor.chassisTemperature.ok
Severity
NOTICE
This message occurs when the chassis temperature is normal.
Corrective Action
(None).
Syslog Message
Chassis temperature is ok.
(None).
monitor.chassisTemperature.state.unknown
Severity
ALERT
This message occurs when the system cannot read multiple chassis temperature sensors. The condition can be caused by software, firmware, or hardware problems.
Corrective Action
Arrange to AC power-cycle the unit to address possible software and firmware issues. If the condition persists, contact NetApp technical support for assistance with Processor Control Module (PCM) replacement.
Syslog Message
Chassis temperature state is unknown: %s.
reasonText (STRING): Description of the temperature sensor issue.
monitor.chassisTemperature.warm
Severity
ALERT
This message occurs when the chassis temperature is too warm. This is a warning message. If the condition persists, the system will shut down automatically.
Corrective Action
Ensure that sufficient cooling air is being supplied to the chassis and that the air inlets and outlets of the unit are not blocked. If you cannot resolve the situation, shut down all clients that are attached to the storage appliance, and then shut down the system.
Syslog Message
Chassis temperature is too warm: %s
describe_toowarm (STRING): Description of the condition.
