ONTAP EMS reference
monitor.nvramlowbattery events
monitor.nvramlowbattery EMS events occur when ONTAP encounters issues associated with NVRAM battery power level.
monitor.nvramLowBattery
Severity
EMERGENCY
This message occurs when the NVRAM battery is at a dangerously low power level.
Corrective Action
Replace the NVRAM battery.
Syslog Message
NVRAM battery is dangerously low.
(None).
monitor.nvramLowBattery.notice
Severity
NOTICE
This message occurs when a low battery situation exists. The timeout[123] values are duplicated as a convenience for the Syslog message, which prints out the value three times.
Corrective Action
Syslog Message
If the NVRAM battery is dangerously low, the system shuts down automatically every %d hours to encourage you to replace it. If you reboot the system it will run for another %d hours before shutting down.
timeout1 (INT): Timeout value.
timeout2 (INT): Timeout value.
timeout3 (INT): Timeout value.
