netif.speeddowngraded events
netif.speeddowngraded EMS events occur when the interface is operating at a lower speed than expected.
netif.speedDowngraded
- Severity
ERROR
- Description
This message occurs when the interface is operating at a lower speed than expected.
- Corrective Action
The physical connection may be faulty. Replace the cable and check the switch port configuration for errors.
- Syslog Message
Interface %s operating at %d Mbps. This might occur due to faulty cable, faulty switch hardware, or faulty switch software.
- Parameters
ifName (STRING): Name of the network interface.
speed (INT): Speed used by the interface.
