ONTAP EMS reference
nvmf.tcp events
nvmf.tcp EMS events occur when ONTAP encounters issues associated with NVMe-over-TCP (NVMe/TCP) operations.
nvmf.tcp.lif.create.fail
Severity
ERROR
This message occurs when there is an internal error while creating a NVMe-over-TCP (NVMe/TCP) logical network interface (LIF).
Corrective Action
To recover from this condition, use the "network interface modify" command to change the state of "status-admin" of the LIF to "down" and then back to "up" again.
Syslog Message
NVMe/TCP LIF "%s" create operation failed because of the following internal error: "%d".
lifname (STRING): Name of the NVMe/TCP LIF that encountered the failure.
errorCode (INT): Error code returned during the creation of the LIF.
nvmf.tcp.trans.init.fail
Severity
ERROR
This message occurs when there is an internal error during the NVMe-over-TCP (NVMe/TCP) transport initialization.
Corrective Action
NVMe-oF logs at "/mroot/etc/log/rastrace" need to be collected for further analysis. Trigger an ALL AutoSupport® message by using the following command: "autosupport invoke -node * -message "nvmf.tcp.transport.init.failed" -type all". Also trigger the diagnostic AutoSupport function by using the following command "autosupport invoke-diagnostic -node * -message "nvmf.tcp.transport.init.failed" -subsystems nvmf". Then contact NetApp technical support support.
Syslog Message
NVMe/TCP transport initialization failed because of the following internal error: "%d".
errorCode (INT): Error code returned during transport initialization.
