ONTAP EMS reference
raid.disable events
raid.disable EMS events occur when RAID sub system disables recording in the partner's NVRAM entries for the log based file system.
raid.disable.remote.nvlog
Severity
INFORMATIONAL
This event is issued when RAID sub system disables recording in the partner's NVRAM entries for the log based file system.
Corrective Action
Need to replace NVRAM if observed repeatedly during different boot-ups.
Syslog Message
Disabled Remote NVRAM logging.
(None).
