ONTAP EMS reference
reg.transaction events
reg.transaction EMS events occur when ONTAP encounters issues associated with registry transaction commits.
reg.transaction.commitFail
Severity
ERROR
This message occurs when ONTAP® cannot commit a registry transaction. A system registry transaction is used to update a group of registry keys simultaneously.
Corrective Action
Check to see whether the system is running low on memory. Contact NetApp technical support.
Syslog Message
registry: Cannot commit transaction in '%s'. %s
location (STRING): Location where the failure occurred.
errormsg (STRING): Internal error message explaining why the transaction commit failed.
reg.transaction.createFail
Severity
ERROR
This message occurs when ONTAP® software cannot create a registry transaction. A system registry transaction is used to update a group of registry keys simultaneously.
Corrective Action
Syslog Message
registry: Cannot create transaction. Operation: %s.
operation (STRING): Registry operation involved in the failure.
reg.transaction.setkeyFail
Severity
ALERT
This message occurs when ONTAP® cannot set a registry key to a value within a registry transaction.
Corrective Action
Because the transaction failed, modify the registry key manually. Follow the steps in KB article https://kb.netapp.com/support/index?page=content&actp=LIST&id=S:1015964.
Syslog Message
registry: Transaction cannot set "%s" to "%s".
key (STRING): Registry key that should have been changed.
value (STRING): Value that the key should have been changed to.
