ONTAP EMS reference
replication.global events
replication.global EMS events occur when the request to change/set the throttling value for a replication association is failed.
replication.global.throttle
Severity
NOTICE
This event is issued when the request to change/set the throttling value for a replication association is failed. This is because the network layer does not support throttling traffic. This usually happens when the connection is going through a tcp offload device.
Corrective Action
(None).
Syslog Message
Failed to set global throttle value for transfer from %s:%s to %s:%s
srcfiler (STRING): The replication source filer
srcpath (STRING): The replication src volume or qtree
dstfiler (STRING): The replication destination filer
dstpath (STRING): The replication destination volume or qtree
