ONTAP EMS reference
sfu.partnernotresponding events
sfu.partnernotresponding EMS events occur when one node in a high-availability (HA) configuration does not respond to firmware download requests from another node, in which case the other node cannot download disk shelf firmware.
sfu.partnerNotResponding
Severity
ALERT
This message occurs when one node in a high-availability (HA) configuration does not respond to firmware download requests from another node, in which case the other node cannot download disk shelf firmware.
Corrective Action
Make certain that the HA interconnect is up and running on both nodes of the HA pair and then attempt to re-download disk shelf firmware, using the (advanced privilege) "storage shelf firmware update" command.
Syslog Message
Partner either responded in the negative, or did not respond in %d seconds. Aborting shelf firmware update.
timeout (INT): Number of seconds the timeout is set for.
