ONTAP EMS reference
sm.cg events
sm.cg EMS events occur when there is a failure to replicate tag information to a SnapMirror destination consistency group as part of a SnapMirror operation.
sm.cg.tag.replicate.fail
Severity
ERROR
This message occurs when there is a failure to replicate tag information to a SnapMirror destination consistency group as part of a SnapMirror operation. This results in a mismatch of consistency group tags data found in source and destination consistency groups.
Corrective Action
A subsequent SnapMirror (SM) auto-update or user-triggered manual SM update will replicate the tags. Make sure that this event is no longer seen after the latest SM update. Command to update manually: snapmirror update -destination-path 'SVM-name':/cg/'cg-name' Command to check the last update: snapmirror show -destination-path 'SVM-name':/cg/'cg-name' -instance
Syslog Message
SnapMirror operation failed to replicate tag information from primary consistency group (CG) to secondary CG. SnapMirror relationship ID: "%s", Error: "%s"
relID (STRING): SnapMirror relationship ID for which tag replication fails.
reason (STRING): Reason for the tag replication failure.
