ONTAP EMS reference
sm.fgmirror events
sm.fgmirror EMS events occur when improper group workflow cleanup caused the subsequent SnapMirror® operation to fail.
sm.fgmirror.stale.grp.wkflw
Severity
ERROR
This message occurs when improper group workflow cleanup caused the subsequent SnapMirror® operation to fail.
Corrective Action
Run the "snapmirror abort -h {-relationship-id <relationshipID>}" command, and then retry the SnapMirror operation.
Syslog Message
SnapMirror operation on relationship with relationshipID %s failed because of an existing stale group workflow.
relationshipID (STRING): UUID of the SnapMirror relationship.
