ONTAP EMS reference
snapmirror.corrupted events
snapmirror.corrupted EMS events occur when metadata replay fails in the process of making a Synchronous SnapMirror® destination flexible volume writable.
snapmirror.corrupted.replay
Severity
ALERT
This message occurs when metadata replay fails in the process of making a Synchronous SnapMirror® destination flexible volume writable. This failure occurs because the filesystem on disk is corrupt.
Corrective Action
This error will not allow the destination volume to be made writable. Wafliron must be run on the destination to correct the filesystem consistency. Once the inconsistency is fixed, snapmirror break can be attempted again.
Syslog Message
Synchronous SnapMirror cannot proceed with snapmirror break for volume '%s' in containing aggregate '%s' because the filesystem on disk is corrupt.
dst_volume (STRING): The name of the Synchronous SnapMirror® destination volume
dst_aggr (STRING): The name of the aggregate containing the destination volume
