spm.bcomd events
spm.bcomd EMS events occur when the Blocks Configuration and Operations Manager Daemon (BCOMd) aborts.
spm.bcomd.process.exit
- Severity
ALERT
- Description
This message occurs when the Blocks Configuration and Operations Manager Daemon (BCOMd) aborts. This can be due to one or more causes and might be related to some recent or previous operations.
- Corrective Action
The system attempts to recover by restarting the daemon. If the daemon does not recover within the threshold number of retries, an AutoSupport message is sent. If your system is not configured to send AutoSupport messages and the issue persists, contact NetApp technical support.
- Syslog Message
Blocks Configuration and Operations Manager Daemon (BCOMd) with ID %d aborted as a result of signal %s. The daemon will attempt to restart.
- Parameters
id (INT): Process identifier.
cause (STRING): Plain text description of why the process aborted.
