ONTAP EMS reference
wafl.fa events
wafl.fa EMS events occur when ONTAP encounters issues associated with FlexAggregate synchronization and consistency.
wafl.fa.iron.sync.waiting
Severity
NOTICE
This message occurs when a FlexAggregate is waiting for other FlexAggregates to reach the same iron state. Failure to reach the same iron state stalls wafliron running on the storage pod.
Corrective Action
Run "wafliron status" on the storage pod to check state of other FlexAggregates.
Syslog Message
FlexAggregate "%s" is waiting for other FlexAggregates to reach the iron state : %s.
flexaggrname (STRING): FlexAggregate name.
iron_state (STRING): Current iron state of the FlexAggregate.
wafl.fa.mark.inconsistent
Severity
ALERT
This message occurs when an aggregate is being marked inconsistent.
Corrective Action
Contact NetApp technical support.
Syslog Message
Flexaggr with ID: "%d" is marked inconsistent due to "%s". Call support for assistance.
flexaggr_id (INT): ID of the flexaggregate.
reason (STRING): Reason for EMS being triggered.
