ONTAP Mediator
Configure ONTAP Mediator attributes
Contributors netapp-aoife netapp-camdenc
You can configure ONTAP Mediator host-side attributes, including certificate-related settings and configuration overrides.
ONTAP Mediator configurable settings
ONTAP Mediator supports several configurable settings. The default values for these settings are provided in a ontap_mediator.config.yaml read-only file. The file is located at:
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/ontap_mediator.user_config.yaml
All values that are placed in the ontap_mediator.user_config.yaml will override the default values and be maintained across all ONTAP Mediator upgrades.
After you modify ontap_mediator.user_config.yaml, restart ONTAP Mediator:
systemctl restart ontap_mediator
The ONTAP Mediator attributes described in this section can be modified if required.
Note Other default values in the ontap_mediator.config.yaml should not be changed because modified values are not maintained during ONTAP Mediator upgrades.
You modify ONTAP Mediator attributes by copying the required variables to the ontap_mediator.user_config.yaml file to override the default settings.
Install third-party SSL certificates
You can replace the default self-signed certificates with third-party SSL certificates by modifying the ONTAP Mediator configuration files.
To replace the default self-signed certificates with third-party SSL certificates, you modify certain attributes in the following files:
  • /opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/ontap_mediator.config.yaml
  • /opt/netapp/lib/ontap_mediator/uwsgi/ontap_mediator.ini
The variables in these files are used to control the certificate files used by ONTAP Mediator.
ONTAP Mediator 1.9 and later
The default variables listed in the following table are included in the /opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/ontap_mediator.config.yaml file.
Variable Path
cert_path
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/ontap_mediator_server.crt
key_path
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/ontap_mediator_server.key
ca_cert_path
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/intermediate.crt
ca_key_path
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/intermediate.key
ca_serial_path
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/intermediate.srl
cert_valid_days
1095
x509_passin_pwd
pass:ontap
  • cert_valid_days is used to set the expiration of client certificates. The maximum value is three years (1095 days).
  • x509_passin_pwd is the passphrase for the signed client certificate.
The default variables listed in the following table are included in the /opt/netapp/lib/ontap_mediator/uwsgi/ontap_mediator.ini file.
Variable Path
mediator_cert
mediator_key
ca_cert_path
ONTAP Mediator 1.8 and earlier
Variable Path
cert_path
key_path
ca_cert_path
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/ca.crt
ca_key_path
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/ca.key
ca_serial_path
/opt/netapp/lib/ontap_mediator/ontap_mediator/server_config/ca.srl
cert_valid_days
1095
x509_passin_pwd
pass:ontap
Variable Path
mediator_cert
mediator_key
ca_cert_path
If you modify these attributes, restart ONTAP Mediator to apply the changes. For detailed instructions on how to replace default certificates with third-party certificates, refer to Replace self-signed certificates with trusted third-party certificates.
Configure password attack protection
The following settings provide protection against brute-force password guessing attacks.
To enable the feature, set a value for the window_seconds and the retry_limit.
Examples:
  • Provide a 5-minute window for guesses, and then reset the count to zero failures:
    authentication_lock_window_seconds: 300
  • Lock the account if five failures occur within the window timeframe:
    authentication_retry_limit: 5
  • Reduce the impact of brute-force password guessing attacks by setting a delay that occurs prior to rejecting each attempt, which slows the attacks.
    authentication_failure_delay_seconds: 5
    authentication_failure_delay_seconds: 0   # seconds (float) to delay failed auth attempts prior to response, 0 = no delay
    authentication_lock_window_seconds: null  # seconds (int) since the oldest failure before resetting the retry counter, null = no window
    authentication_retry_limit: null          # number of retries to allow before locking API access, null = unlimited
Configure password complexity rules
The following fields control the password complexity rules of the ONTAP Mediator API user account.
password_min_length: 8
password_max_length: 64
password_uppercase_chars: 0    # min. uppercase characters
password_lowercase_chars: 1    # min. lowercase character
password_special_chars: 1      # min. non-letter, non-digit
password_nonletter_chars: 2    # min. non-letter characters (digits, specials, anything)
Configure ONTAP Mediator disk and log space settings, including the free-space threshold and reserved log space.
Configure the free-space threshold
There are settings that control the required free space on the /opt/netapp/lib/ontap_mediator disk.
If the space is lower than the set threshold, the service issues a warning event.
low_space_threshold_mib: 10
Configure reserved log space
The RESERVE_LOG_SPACE feature is controlled by specific settings. By default, the ONTAP Mediator installation creates a separate disk space for the logs. The installer creates a new fixed-size file with a total of 700MB of disk space to be used explicitly for ONTAP Mediator logging.
To disable this feature and use the default disk space, perform the following steps:
  1. Change the value of RESERVE_LOG_SPACE from 1 to 0 in the following file:
    /opt/netapp/lib/ontap_mediator/tools/mediator_env
    1. Run the following command:
      cat /opt/netapp/lib/ontap_mediator/tools/mediator_env | grep "RESERVE_LOG_SPACE"
      RESERVE_LOG_SPACE=0
    2. Restart ONTAP Mediator:
To re-enable the feature, change the value from 0 to 1 and restart the Mediator.
Note Toggling between disk spaces does not purge existing logs. All previous logs are backed up and then moved to the current disk space after toggling and restarting the Mediator.
