Moving a metadata volume in MetroCluster configurations
You can move a metadata volume from one aggregate to another aggregate in a MetroCluster configuration. You might want to move a metadata volume when the source aggregate is decommissioned or unmirrored, or for other reasons that make the aggregate ineligible.
You must have cluster administrator privileges to perform this task.
The target aggregate must be mirrored and should not be in the degraded state.
The available space in the target aggregate must be larger than the metadata volume that you are moving.
Set the privilege level to advanced:
set -privilege advanced -
Identify the metadata volume that should be moved:
volume show MDV_CRS*Cluster_A::*> volume show MDV_CRS* Vserver Volume Aggregate State Type Size Available Used% --------- ------------ ------------ ---------- ---- ---------- ---------- ----- Cluster_A MDV_CRS_14c00d4ac9f311e7922800a0984395f1_A Node_A_1_aggr1 online RW 10GB 9.50GB 5% Cluster_A MDV_CRS_14c00d4ac9f311e7922800a0984395f1_B Node_A_2_aggr1 online RW 10GB 9.50GB 5% Cluster_A MDV_CRS_15035e66c9f311e7902700a098439625_A Node_B_1_aggr1 - RW - - - Cluster_A MDV_CRS_15035e66c9f311e7902700a098439625_B Node_B_2_aggr1 - RW - - - 4 entries were displayed. Cluster_A::> -
Identify an eligible target aggregate:
metrocluster check config-replication show-aggregate-eligibilityThe following command identifies the aggregates in cluster_A that are eligible to host metadata volumes:
Cluster_A::*> metrocluster check config-replication show-aggregate-eligibility Aggregate Hosted Config Replication Vols Host Addl Vols Comments ------------ ------------------------------------------ -------------- -------- Node_A_1_aggr0 - false Root Aggregate Node_A_2_aggr0 - false Root Aggregate Node_A_1_aggr1 MDV_CRS_1bc7134a5ddf11e3b63f123478563412_A true - Node_A_2_aggr1 MDV_CRS_1bc7134a5ddf11e3b63f123478563412_B true - Node_A_1_aggr2 - true Node_A_2_aggr2 - true Node_A_1_Aggr3 - false Unable to determine available space of aggregate Node_A_1_aggr5 - false Unable to determine mirror configuration Node_A_2_aggr6 - false Mirror configuration does not match requirement Node_B_1_aggr4 - false NonLocal Aggregate
In the previous example, Node_A_1_aggr2 and Node_A_2_aggr2 are eligible. -
Start the volume move operation:
volume move start -vserver svm_name -volume metadata_volume_name -destination-aggregate destination_aggregate_nameThe following command moves metadata volume
MDV_CRS_14c00d4ac9f311e7922800a0984395f1fromaggregate Node_A_1_aggr1toaggregate Node_A_1_aggr2:Cluster_A::*> volume move start -vserver svm_cluster_A -volume MDV_CRS_14c00d4ac9f311e7922800a0984395f1 -destination-aggregate aggr_cluster_A_02_01 Warning: You are about to modify the system volume "MDV_CRS_9da04864ca6011e7b82e0050568be9fe_A". This may cause severe performance or stability problems. Do not proceed unless directed to do so by support. Do you want to proceed? {y|n}: y [Job 109] Job is queued: Move "MDV_CRS_9da04864ca6011e7b82e0050568be9fe_A" in Vserver "svm_cluster_A" to aggregate "aggr_cluster_A_02_01". Use the "volume move show -vserver svm_cluster_A -volume MDV_CRS_9da04864ca6011e7b82e0050568be9fe_A" command to view the status of this operation. -
Verify the state of the volume move operation:
volume move show -volume vol_constituent_name -
Return to the admin privilege level:
set -privilege admin
