ONTAP MetroCluster
Example naming for a two-node MetroCluster FC-to-IP transition
Contributors netapp-thomi NetAppZacharyWambold netapp-aherbin
This procedure uses example names throughout to identify the DR groups, nodes, and switches involved.
The nodes in the original configuration have the suffix -FC, indicating that they are in a fabric-attached or stretch MetroCluster configuration.
Components
cluster_A at site_A
cluster_B at site_B
dr_group_1-FC
  • node_A_1-FC
  • shelf_A_1
  • shelf_A_2
  • node_B_1-FC
  • shelf_B_1
  • shelf_B_2
dr_group_2-IP
  • node_A_1-IP
  • node_A_2-IP
  • shelf_A_1
  • shelf_A_2
  • shelf_A_3-new
  • shelf_A_4-new
  • node_B_1-IP
  • node_B_2-IP
  • shelf_B_1
  • shelf_B_2
  • shelf_B_3-new
  • shelf_B_4-new
Switches
  • switch_A_1-FC
  • switch_A_2-FC
  • switch_A_1-IP
  • switch_A_2-IP
  • switch_B_1-FC
  • switch_B_2-FC
  • switch_B_1-IP
  • switch_B_2-IP
