Clear the configuration on a controller module during a four-node MetroCluster FC expansion
Before using a new controller module in the MetroCluster configuration, you must clear the existing configuration.
Steps
If necessary, halt the node to display the
LOADERprompt:halt -
At the
LOADERprompt, set the environmental variables to default values:set-defaults -
Save the environment:
saveenv -
At the
LOADERprompt, launch the boot menu:boot_ontap menu -
At the boot menu prompt, clear the configuration:
wipeconfigRespond
yesto the confirmation prompt.The node reboots and the boot menu is displayed again.
At the boot menu, select option 5 to boot the system into Maintenance mode.
Respond
