Configure intercluster LIFs during a four-node to eight-node MetroCluster FC expansion
Learn how to configure intercluster LIFs on dedicated and shared ports during a four-node to eight-node MetroCluster FC expansion.
You can configure intercluster LIFs on dedicated ports to increase the available bandwidth for replication traffic.
List the ports in the cluster:
network port showFor complete command syntax, see the man page.
The following example shows the network ports in cluster01:
cluster01::> network port show Speed (Mbps) Node Port IPspace Broadcast Domain Link MTU Admin/Oper ------ --------- ------------ ---------------- ----- ------- ------------ cluster01-01 e0a Cluster Cluster up 1500 auto/1000 e0b Cluster Cluster up 1500 auto/1000 e0c Default Default up 1500 auto/1000 e0d Default Default up 1500 auto/1000 e0e Default Default up 1500 auto/1000 e0f Default Default up 1500 auto/1000 cluster01-02 e0a Cluster Cluster up 1500 auto/1000 e0b Cluster Cluster up 1500 auto/1000 e0c Default Default up 1500 auto/1000 e0d Default Default up 1500 auto/1000 e0e Default Default up 1500 auto/1000 e0f Default Default up 1500 auto/1000 -
Determine which ports are available to dedicate to intercluster communication:
network interface show -fields home-port,curr-portFor complete command syntax, see the man page.
The following example shows that ports "e0e" and "e0f" have not been assigned LIFs:
cluster01::> network interface show -fields home-port,curr-port vserver lif home-port curr-port ------- -------------------- --------- --------- Cluster cluster01-01_clus1 e0a e0a Cluster cluster01-01_clus2 e0b e0b Cluster cluster01-02_clus1 e0a e0a Cluster cluster01-02_clus2 e0b e0b cluster01 cluster_mgmt e0c e0c cluster01 cluster01-01_mgmt1 e0c e0c cluster01 cluster01-02_mgmt1 e0c e0c -
Create a failover group for the dedicated ports:
network interface failover-groups create -vserver <system_SVM> -failover-group <failover_group> -targets <physical_or_logical_ports>The following example assigns ports "e0e" and "e0f" to the failover group "intercluster01" on the system SVM "cluster01":
cluster01::> network interface failover-groups create -vserver cluster01 -failover-group intercluster01 -targets cluster01-01:e0e,cluster01-01:e0f,cluster01-02:e0e,cluster01-02:e0f
Verify that the failover group was created:
network interface failover-groups showFor complete command syntax, see the man page.
cluster01::> network interface failover-groups show Failover Vserver Group Targets ---------------- ---------------- -------------------------------------------- Cluster Cluster cluster01-01:e0a, cluster01-01:e0b, cluster01-02:e0a, cluster01-02:e0b cluster01 Default cluster01-01:e0c, cluster01-01:e0d, cluster01-02:e0c, cluster01-02:e0d, cluster01-01:e0e, cluster01-01:e0f cluster01-02:e0e, cluster01-02:e0f intercluster01 cluster01-01:e0e, cluster01-01:e0f cluster01-02:e0e, cluster01-02:e0f -
Create intercluster LIFs on the system SVM and assign them to the failover group.
ONTAP version
Command
9.6 and later
network interface create -vserver <system_SVM> -lif <LIF_name> -service-policy default-intercluster -home-node <node> -home-port <port> -address <port_IP> -netmask <netmask> -failover-group <failover_group>9.5 and earlier
network interface create -vserver system_SVM -lif <LIF_name> -role intercluster -home-node <node> -home-port <port> -address <port_IP> -netmask <netmask> -failover-group <failover_group>For complete command syntax, see the man page.
The following example creates intercluster LIFs "cluster01_icl01" and "cluster01_icl02" in the failover group "intercluster01":
cluster01::> network interface create -vserver cluster01 -lif cluster01_icl01 -service- policy default-intercluster -home-node cluster01-01 -home-port e0e -address 192.168.1.201 -netmask 255.255.255.0 -failover-group intercluster01 cluster01::> network interface create -vserver cluster01 -lif cluster01_icl02 -service- policy default-intercluster -home-node cluster01-02 -home-port e0e -address 192.168.1.202 -netmask 255.255.255.0 -failover-group intercluster01
Verify that the intercluster LIFs were created:
In ONTAP 9.6 and later:
network interface show -service-policy default-interclusterIn ONTAP 9.5 and earlier:
network interface show -role interclusterFor complete command syntax, see the man page.
cluster01::> network interface show -service-policy default-intercluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- cluster01 cluster01_icl01 up/up 192.168.1.201/24 cluster01-01 e0e true cluster01_icl02 up/up 192.168.1.202/24 cluster01-02 e0f true -
Verify that the intercluster LIFs are redundant:
network interface show -service-policy default-intercluster -failoverIn ONTAP 9.5 and earlier:
network interface show -role intercluster -failoverFor complete command syntax, see the man page.
The following example shows that the intercluster LIFs "cluster01_icl01" and "cluster01_icl02" on the SVM "e0e" port will fail over to the "e0f" port.
cluster01::> network interface show -service-policy default-intercluster –failover Logical Home Failover Failover Vserver Interface Node:Port Policy Group -------- --------------- --------------------- --------------- -------- cluster01 cluster01_icl01 cluster01-01:e0e local-only intercluster01 Failover Targets: cluster01-01:e0e, cluster01-01:e0f cluster01_icl02 cluster01-02:e0e local-only intercluster01 Failover Targets: cluster01-02:e0e, cluster01-02:e0f
You can configure intercluster LIFs on ports shared with the data network to reduce the number of ports you need for intercluster networking.
cluster01::> network port show Speed (Mbps) Node Port IPspace Broadcast Domain Link MTU Admin/Oper ------ --------- ------------ ---------------- ----- ------- ------------ cluster01-01 e0a Cluster Cluster up 1500 auto/1000 e0b Cluster Cluster up 1500 auto/1000 e0c Default Default up 1500 auto/1000 e0d Default Default up 1500 auto/1000 cluster01-02 e0a Cluster Cluster up 1500 auto/1000 e0b Cluster Cluster up 1500 auto/1000 e0c Default Default up 1500 auto/1000 e0d Default Default up 1500 auto/1000 -
Create intercluster LIFs on the system SVM:
network interface create -vserver <system_SVM> -lif <LIF_name> -service-policy default-intercluster -home-node <node> -home-port <port> -address <port_IP> -netmask <netmask>In ONTAP 9.5 and earlier:
network interface create -vserver <system_SVM> -lif <LIF_name> -role intercluster -home-node <node> -home-port <port> -address <port_IP> -netmask <netmask>For complete command syntax, see the man page.
cluster01_icl01andcluster01_icl02:cluster01::> network interface create -vserver cluster01 -lif cluster01_icl01 -service- policy default-intercluster -home-node cluster01-01 -home-port e0c -address 192.168.1.201 -netmask 255.255.255.0 cluster01::> network interface create -vserver cluster01 -lif cluster01_icl02 -service- policy default-intercluster -home-node cluster01-02 -home-port e0c -address 192.168.1.202 -netmask 255.255.255.0
cluster01::> network interface show -service-policy default-intercluster Logical Status Network Current Current Is Vserver Interface Admin/Oper Address/Mask Node Port Home ----------- ---------- ---------- ------------------ ------------- ------- ---- cluster01 cluster01_icl01 up/up 192.168.1.201/24 cluster01-01 e0c true cluster01_icl02 up/up 192.168.1.202/24 cluster01-02 e0c true -
network interface show –service-policy default-intercluster -failoverIn ONTAP 9.5 and earlier:
The following example shows that the intercluster LIFs "cluster01_icl01" and "cluster01_icl02" on the "e0c" port will fail over to the "e0d" port.
cluster01::> network interface show -service-policy default-intercluster –failover Logical Home Failover Failover Vserver Interface Node:Port Policy Group -------- --------------- --------------------- --------------- -------- cluster01 cluster01_icl01 cluster01-01:e0c local-only 192.168.1.201/24 Failover Targets: cluster01-01:e0c, cluster01-01:e0d cluster01_icl02 cluster01-02:e0c local-only 192.168.1.201/24 Failover Targets: cluster01-02:e0c, cluster01-02:e0d
