ONTAP MetroCluster
Update the switch RCFs and set the MetroCluster IP bootarg values
Contributors netapp-aoife
Update the switch reference configuration files (RCFs) for the new platforms and set the MetroCluster IP bootarg values on the controller modules.
Update the switch RCFs to accommodate the new platforms
You must update the switches to a configuration that supports the new platform models.
About this task
You perform this task at the site containing the controllers that are currently being upgraded. In the examples shown in this procedure we are upgrading site_B first.
The switches at site_A will be upgraded when the controllers on site_A are upgraded.
Steps
  1. Prepare the IP switches for the application of the new reference configuration files (RCFs).
    Follow the steps in the section for your switch vendor:
  2. Download and install the RCFs.
Set the MetroCluster IP bootarg variables
Certain MetroCluster IP bootarg values must be configured on the new controller modules. The values must match those configured on the old controller modules.
About this task
  • You need the UUIDs and system IDs identified earlier in the upgrade procedure in Gather information before the upgrade.
  • Depending on your platform model, you can specify the VLAN ID using the -vlan-id parameter. The following platforms do not support the -vlan-id parameter:
    • FAS8200 and AFF A300
    • AFF A320
    • FAS9000 and AFF A700
    • AFF C800, ASA C800, AFF A800, and ASA A800
      All other platforms support the -vlan-id parameter.
  • The MetroCluster bootarg values you set depend on whether your new system uses shared cluster/HA ports or shared MetroCluster/HA ports.
    Shared cluster/HA ports
    The systems listed in the following table use shared cluster/HA ports:
    AFF and ASA systems FAS systems
    • AFF A20
    • AFF A30
    • AFF C30
    • AFF A50
    • AFF C60
    • AFF C80
    • AFF A70
    • AFF A90
    • AFF A1K
    • FAS50
    • FAS70
    • FAS90
    Shared MetroCluster/HA ports
    The systems listed in the following table use shared MetroCluster/HA ports:
    • AFF A150, ASA A150
    • AFF A220
    • AFF C250, ASA C250
    • AFF A250, ASA A250
    • AFF A300
    • AFF A320
    • AFF C400, ASA C400
    • AFF A400, ASA A400
    • AFF A700
    • AFF A800, ASA A800
    • AFF A900, ASA A900
    • FAS2750
    • FAS500f
    • FAS8200
    • FAS8300
    • FAS8700
    • FAS9000
    • FAS9500
Steps
  1. At the LOADER> prompt, set the following bootargs on the new nodes at site_B:
    The steps you follow depends on the ports used by the new platform model.
    Systems that use shared cluster/HA ports
    1. Set the following bootargs:
      setenv bootarg.mcc.port_a_ip_config <local-IP-address/local-IP-mask,0,0,DR-partner-IP-address,DR-aux-partnerIP-address,vlan-id>
      setenv bootarg.mcc.port_b_ip_config <local-IP-address/local-IP-mask,0,0,DR-partner-IP-address,DR-aux-partnerIP-address,vlan-id>
      Note If the interfaces are using a default VLAN ID, the vlan-id parameter is not required.
      The following example sets the values for node_B_1-new using VLAN 120 for the first network and VLAN 130 for the second network:
      setenv bootarg.mcc.port_a_ip_config 172.17.26.10/23,0,0,172.17.26.13,172.17.26.12,120
      setenv bootarg.mcc.port_b_ip_config 172.17.27.10/23,0,0,172.17.27.13,172.17.27.12,130
      The following example sets the values for node_B_2-new using VLAN 120 for the first network and VLAN 130 for the second network:
      setenv bootarg.mcc.port_a_ip_config 172.17.26.11/23,0,0,172.17.26.12,172.17.26.13,120
      setenv bootarg.mcc.port_b_ip_config 172.17.27.11/23,0,0,172.17.27.12,172.17.27.13,130
      The following example sets the values for node_B_1-new using default VLANs for all MetroCluster IP DR connections:
      The following example sets the values for node_B_2-new using default VLANs for all MetroCluster IP DR connections:
    Systems that use shared MetroCluster/HA ports
      setenv bootarg.mcc.port_a_ip_config <local-IP-address/local-IP-mask,0,HA-partner-IP-address,DR-partner-IP-address,DR-aux-partnerIP-address,vlan-id>
      setenv bootarg.mcc.port_b_ip_config <local-IP-address/local-IP-mask,0,HA-partner-IP-address,DR-partner-IP-address,DR-aux-partnerIP-address,vlan-id>
      setenv bootarg.mcc.port_a_ip_config 172.17.26.10/23,0,172.17.26.11,172.17.26.13,172.17.26.12,120
      setenv bootarg.mcc.port_b_ip_config 172.17.27.10/23,0,172.17.27.11,172.17.27.13,172.17.27.12,130
      setenv bootarg.mcc.port_a_ip_config 172.17.26.11/23,0,172.17.26.10,172.17.26.12,172.17.26.13,120
      setenv bootarg.mcc.port_b_ip_config 172.17.27.11/23,0,172.17.27.10,172.17.27.12,172.17.27.13,130
  2. At the new nodes' LOADER prompt, set the UUIDs:
    setenv bootarg.mgwd.partner_cluster_uuid <partner-cluster-UUID>
    setenv bootarg.mgwd.cluster_uuid <local-cluster-UUID>
    setenv bootarg.mcc.pri_partner_uuid <DR-partner-node-UUID>
    setenv bootarg.mcc.aux_partner_uuid <DR-aux-partner-node-UUID>
    setenv bootarg.mcc_iscsi.node_uuid <local-node-UUID>
    1. Set the UUIDs on node_B_1-new.
      The following example shows the commands for setting the UUIDs on node_B_1-new:
      setenv bootarg.mgwd.cluster_uuid ee7db9d5-9a82-11e7-b68b-00a098908039
      setenv bootarg.mgwd.partner_cluster_uuid 07958819-9ac6-11e7-9b42-00a098c9e55d
      setenv bootarg.mcc.pri_partner_uuid f37b240b-9ac1-11e7-9b42-00a098c9e55d
      setenv bootarg.mcc.aux_partner_uuid bf8e3f8f-9ac4-11e7-bd4e-00a098ca379f
      setenv bootarg.mcc_iscsi.node_uuid f03cb63c-9a7e-11e7-b68b-00a098908039
    2. Set the UUIDs on node_B_2-new:
      The following example shows the commands for setting the UUIDs on node_B_2-new:
      setenv bootarg.mcc.pri_partner_uuid bf8e3f8f-9ac4-11e7-bd4e-00a098ca379f
      setenv bootarg.mcc.aux_partner_uuid f37b240b-9ac1-11e7-9b42-00a098c9e55d
      setenv bootarg.mcc_iscsi.node_uuid aa9a7a7a-9a81-11e7-a4e9-00a098908c35
  3. Determine whether the original systems were configured for Advanced Drive Partitioning (ADP) by running the following command from the site that is up:
    disk show
    The "container type" column displays "shared" in the disk show output if ADP is configured. If "container type" has any other value, ADP is not configured on the system. The following example output shows a system configured with ADP:
    ::> disk show
                        Usable               Disk    Container   Container
    Disk                Size       Shelf Bay Type    Type        Name      Owner
    Info: This cluster has partitioned disks. To get a complete list of spare disk
          capacity use "storage aggregate show-spare-disks".
    1.11.0              894.0GB    11    0   SSD      shared     testaggr  node_A_1
    1.11.1              894.0GB    11    1   SSD      shared     testaggr  node_A_1
    1.11.2              894.0GB    11    2   SSD      shared     testaggr  node_A_1
  4. If the original systems were configured with partitioned disks for ADP, enable it at the LOADER prompt for each replacement node:
    setenv bootarg.mcc.adp_enabled true
  5. Set the following variables:
    setenv bootarg.mcc.local_config_id <original-sys-id>
    setenv bootarg.mcc.dr_partner <dr-partner-sys-id>
    Note The setenv bootarg.mcc.local_config_id variable must be set to the sys-id of the original controller module, node_B_1-old.
    1. Set the variables on node_B_1-new.
      The following example shows the commands for setting the values on node_B_1-new:
      setenv bootarg.mcc.local_config_id 537403322
      setenv bootarg.mcc.dr_partner 537403324
    2. Set the variables on node_B_2-new.
      The following example shows the commands for setting the values on node_B_2-new:
      setenv bootarg.mcc.local_config_id 537403321
      setenv bootarg.mcc.dr_partner 537403323
  6. If using encryption with external key manager, set the required bootargs:
    setenv bootarg.kmip.init.ipaddr
    setenv bootarg.kmip.kmip.init.netmask
    setenv bootarg.kmip.kmip.init.gateway
    setenv bootarg.kmip.kmip.init.interface
