ONTAP performance counter mapping
copy_manager
The ONTAP copy subsystem (OCS) is the ONTAP component that processes copy-offload requests from multiple protocols. It enables a host to offload data transfer between a source and a destination within the storage array. Based on the scope of this transfer, these requests can be processed by one or more of the OCS copy engines. These include the single instance storage clone copy engine (SCE) for intra-volume copies, the byte copy engine (BCE) for inter-volume copies and the SpinNP copy engine (SpinCE) for copying across nodes in a cluster. The copy manager table reports counters that track copy-offload requests processed by the OCS copy engines and related errors.
Classic Object: copy_manager
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{node.name}:{instance_name}:{instance_uuid}
constituent
This represents the construction of a row ID field for a row from a single node.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Name of the constituent Copy Manager row
node_uuid
node.uuid
UUID for the constituent Copy Manager row
instance_name
name
Name of the Copy Manager SVM row
vserver_name
svm.name
vserver_uuid
svm.uuid
UUID for the Copy Manager SVM row
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
copy_reqs
copy_requests
Sum of Copy Requests received by OCM.
abort_reqs
abort_requests
Sum of Abort Requests received by OCM.
status_reqs
status_requests
Sum of Status Requests received by OCM.
copy_notify_reqs
copy_notify_requests
Sum of Copy Notify Requests received by OCM.
copy_revoke_reqs
copy_revoke_requests
Sum of Copy Revoke Requests received by OCM.
intranode_intravol_copy_reqs
intranode_intravol_copy_requests
Sum of Intra-node Intra-volume Copy Requests received.
intranode_intervol_copy_reqs
intranode_intervol_copy_requests
Sum of Intra-node Inter-volume Copy Requests received.
internode_copy_reqs
internode_copy_requests
Sum of Inter-node Copy Requests received.
copy_authchecks
copy_authchecks
Sum of Copy Requests received requesting an authorization check.
KB_copied
KB_copied
Sum of kilo-bytes copied.
KB_hole_punched
KB_hole_punched
Sum of kilo-bytes that were hole-punched.
copy_notify_failures
Sum of Copy Notify failures.
copy_revoke_failures
Sum of Copy Revoke failures.
copy_authcheck_failures
Sum of Copy Authorization failures.
copy_failures
copy_failures
Sum of Copy Request failures.
copy_fail_no_resource
Sum of copy engine failures for: out of resources.
copy_fail_authfailure
Sum of copy engine failures for: authentication failure.
copy_fail_isdir
copy_fail_is_directory
Sum of copy engine failures for: WAFL, is directory.
copy_fail_nospace
copy_fail_no_space
Sum of copy engine failures for: WAFL, no space.
copy_fail_diskquota
copy_fail_disk_quota
Sum of copy engine failures for: WAFL, disk quota.
copy_fail_jukebox
copy_fail_could_grow
Sum of copy engine failures for: WAFL, low space, could grow.
copy_fail_offline
copy_fail_offline
Sum of copy engine failures for: WAFL, is offline.
copy_fail_staleFH
copy_fail_stale_filehandle
Sum of copy engine failures for: WAFL, stale filehandle.
copy_fail_io
copy_fail_io
Sum of copy engine failures for: WAFL, input/output error.
copy_fail_readonly
copy_fail_read_only
Sum of copy engine failures for: WAFL, destination is read only.
copy_fail_dataunrecov
copy_fail_data_unrecoverable
Sum of copy engine failures for: WAFL, data is unrecoverable.
copy_fail_bad_msgparm
copy_fail_bad_msg_parameter
Sum of copy engine failures for: OCM, invalid msg parameter.
copy_fail_vol_moving
copy_fail_volume_moving
Sum of copy engine failures for: WAFL, data is moving.
copy_fail_no_volume
copy_fail_no_volume
Sum of copy engine failures for: WAFL, volume not available.
copy_fail_delayed
copy_fail_delayed
Sum of copy engine failures for: WAFL, request was delayed.
copy_fail_must_retry
Sum of copy engine failures for: WAFL, retry request encountered.
copy_fail_op_not_permitted
Sum of copy engine failures for: WAFL, operation not permitted.
copy_fail_no_access
copy_fail_no_access
Sum of copy engine failures for: WAFL, access error encountered.
copy_fail_virus_detected
Sum of copy engine failures for: WAFL, virus detected.
copy_fail_data_underrun
Sum of copy engine failures for: WAFL, not enough data copied.
copy_fail_data_overrun
Sum of copy engine failures for: WAFL, too much data copied.
copy_fail_locking_issue
Sum of copy engine failures for: WAFL, locking error encountered.
copy_fail_fencing_issue
Sum of copy engine failures for: WAFL, fencing error encountered.
copy_fail_other
copy_fail_other
Sum of copy engine failures for: WAFL, other WAFL error.
ocs_copy_count_curr
ontap_copy_subsystem_current_copy_count
Current number of copy requests being processed by the ONTAP copy subsystem.
ocs_copy_count_hwm
ontap_copy_subsystem_copy_count_peak
Highest number of concurrent copy requests encountered by the ONTAP copy
subsystem.
sce_copy_count_curr
system_continuous_engineering_current_copy_count
Current number of copy requests being processed by the System Continuous
Engineering.
sce_copy_count_hwm
system_continuous_engineering_copy_count_peak
Highest number of concurrent copy requests encountered by the System Continuous
Engineering.
bce_copy_count_curr
block_copy_engine_current_copy_count
Current number of copy requests being processed by the Block Copy Engine.
bce_copy_count_hwm
block_copy_engine_copy_count_peak
Highest number of concurrent copy requests encountered by the Block Copy Engine.
spince_copy_count_curr
spince_current_copy_count
Current number of copy requests being processed by the SpinCE.
spince_copy_count_hwm
spince_copy_count_peak
Highest number of concurrent copy requests encountered by the SpinCE.
bce_copy_reqs
block_copy_engine_copy_requests
Sum of Block Copy Engine Copy Requests received.
sce_copy_reqs
system_continuous_engineering_copy_requests
Sum of Sisclone Copy Engine Copy Requests received.
sce_kb_copied
system_continuous_engineering_KB_copied
Sum of Sisclone Copy Engine KB copied.
bce_kb_copied
block_copy_engine_KB_copied
Sum of Block Copy Engine KB copied.
spince_kb_copied
spince_KB_copied
Sum of Spinnp Copy Engine KB copied.
bce_ops
bce_ops
Number of byte copy engine requests array with respect to size of operation.
bce_time_latency
bce_time_latency
Byte copy engine average latency array with respect to size of operation.
sce_ops
sce_ops
Number of sisclone copy engine requests array with respect to size of operation.
sce_time_latency
sce_time_latency
Sisclone copy engine average latency array with respect to size of operation.
spince_ops
spince_ops
Number of spinnp copy engine requests array with respect to size of operation.
spince_time_latency
spince_time_latency
Spinnp copy engine average latency array with respect to size of operation.
copy_latency_hist
copy_latency_histogram
Latency histogram for copy operations
bce_latency_hist
bce_latency_histogram
Latency histogram for byte copy engine copy operations
sce_latency_hist
sce_latency_histogram
Latency histogram for sisclone copy engine copy operations
spince_latency_hist
spince_latency_histogram
Latency histogram for spinnp copy engine copy operations
bce_read_hist
bce_read_histogram
Latency histogram for byte copy engine read operations
bce_write_hist
bce_write_histogram
Latency histogram for byte copy engine write operations
bce_hp_hist
bce_hole_punch_histogram
Latency histogram for byte copy engine hole punch operations
spince_read_hist
spince_read_histogram
Latency histogram for spinnp copy engine read operations
spince_write_hist
spince_write_histogram
Latency histogram for spinnp copy engine write operations
spince_hp_hist
spince_hole_punch_histogram
Latency histogram for spinnp copy engine hole punch operations
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
bce_ops
The labels have changed from bce_ops_512KB to 512KB.
Also bce_ops_greater_than_32MB label has changed to >32MB.
bce_time_latency
The labels have changed from bce_latency_512KB to 512KB.
Also bce_latency_greater_than_32MB label has changed to >32MB.
sce_ops
The labels have changed from sce_ops_512KB to 512KB.
Also sce_ops_greater_than_32MB label has changed to >32MB.
sce_time_latency
The labels have changed from sce_latency_512KB to 512KB.
Also sce_latency_greater_than_32MB label has changed to >32MB.
spince_ops
The labels have changed from spince_ops_512KB to 512KB.
Also spince_latency_greater_than_32MB label has changed to >32MB.
spince_time_latency
The labels have changed from spince_latency_512KB to 512KB.
Table Aliases
This section describes aliases for aggregated tables.
