ONTAP 9.11.1 performance counter mapping
external_cache
This table provides performance metrics and configuration characteristics for a given WAFL External Cache type, such as Flash Cache or the Predictive Cache Statistics simulator. High-level cache behavior can be monitored using these statistics.
Classic Object: ext_cache_obj
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
usage
usage
Percentage of blocks in external cache currently containing valid data
accesses
accesses
External cache accesses per second
disk_reads_replaced
disk_reads_replaced
Estimated number of disk reads per second replaced by cache
hit
hit.total
Number of WAFL buffers served off the external cache
hit_normal_lev0
hit.normal_level_zero
Number of normal level 0 WAFL buffers served off the external cache
hit_metadata_file
hit.metadata_file
Number of metadata file buffers served off the external cache
hit_directory
hit.directory
Number of directory buffers served off the external cache
hit_indirect
hit.indirect
Number of indirect file buffers served off the external cache
miss
miss.total
External cache misses
miss_normal_lev0
miss.normal_level_zero
External cache misses accessing normal level 0 buffers
miss_metadata_file
miss.metadata_file
External cache misses accessing metadata file buffers
miss_directory
miss.directory
External cache misses accessing directory buffers
miss_indirect
miss.indirect
External cache misses accessing indirect file buffers
hit_percent
hit.percent
External cache hit rate
inserts
inserts
Number of WAFL buffers inserted into the external cache
evicts
evicts
Number of blocks evicted from the external cache to make room for new blocks
invalidates
invalidates
Number of blocks invalidated in the external cache
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
