ONTAP 9.11.1 performance counter mapping
headroom_cpu
This table displays message service time variance and message inter-arrival time variance for WAFL, as well as headroom optimal point information for the CPU resource.
Classic Object: resource_headroom_cpu
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
instance_name
name
This is the name of the headroom_cpu row.
instance_uuid
uuid
UUID for the headroom row. This is the UUID of the node.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
current_utilization
current_utilization
Average processor utilization across all processors in the system.
current_utilization_total
elapsed_time
Elapsed time since boot.
current_ops
current_ops
Total number of operations per second (also referred to as dblade ops).
current_intercluster_ops
Total number of operations per second going to the partner node.
current_latency
current_latency
Current operation latency of the resource.
service_time
service_time
Average service time for the CPU resource.
optimal_point_utilization
optimal_point.utilization
Utilization component of the optimal point of the latency/utilization curve.
This counter can provide an average utilization over a range of time.
optimal_point_latency
optimal_point.latency
Latency component of the optimal point of the latency/utilization curve. This
counter can provide an average latency over a range of time.
optimal_point_ops
optimal_point.ops
Ops component of the optimal point derived from the latency/utilization curve.
This counter can provide an average ops over a range of time.
optimal_point_confidence_factor
optimal_point.confidence_factor
Confidence factor for the optimal point value based on the observed resource
latency and utilization. The possible values are: 0 - unknown, 1 - low, 2 -
medium, 3 - high. This counter can provide an average confidence factor over a
range of time.
optimal_point_samples
optimal_point.samples
Base counter for optimal_point_utilization, optimal_point_latency,
optimal_point_confidence_factor, and optimal_point_ops. This is the number of
one-minute samples since bootup.
wafl_hipri_service_time
wafl_high_priority.service_time
WAFL high priority service time variance statistics.
wafl_lopri_service_time
wafl_low_priority.service_time
WAFL low priority service time variance statistics.
wafl_cppri_service_time
wafl_cp_priority.service_time
WAFL cp priority service time variance statistics.
wafl_cppro_service_time
wafl_cppro.service_time
WAFL cp promoted priority service time variance statistics.
wafl_hipri_interarrival_time
wafl_high_priority.interarrival_time
WAFL high priority inter-arrival time variance statistics.
wafl_lopri_interarrival_time
wafl_low_priority.interarrival_time
WAFL low priority inter-arrival time variance statistics.
wafl_cppri_interarrival_time
wafl_cp_priority.interarrival_time
WAFL cp priority inter-arrival time variance statistics.
wafl_cppro_interarrival_time
wafl_cppro.interarrival_time
WAFL cp promoted priority inter-arrival time variance statistics.
wafl_mpio_read_service_time
wafl_mpio.read_service_time
WAFL MP I/O successful read service time variance statistics.
ewma_hourly
ewma.hourly
Hourly exponential weighted moving average for current_ops, optimal_point_ops,
current_latency, optimal_point_latency, current_utilization,
optimal_point_utilization and optimal_point_confidence_factor.
ewm_std_dev_hourly
ewm_std_dev.hourly
Hourly exponential weighted moving standard deviation based on one-minute
average values, for current_ops, optimal_point_ops, current_latency,
optimal_point_latency, current_utilization and optimal_point_utilization.
ewma_daily
ewma.daily
Daily exponential weighted moving average for current_ops, optimal_point_ops,
ewm_std_dev_daily
ewm_std_dev.daily
Daily exponential weighted moving standard deviation based on one-minute average
ewma_weekly
ewma.weekly
Weekly exponential weighted moving average for current_ops, optimal_point_ops,
ewm_std_dev_weekly
ewm_std_dev.weekly
Weekly exponential weighted moving standard deviation based on one-minute
ewma_monthly
ewma.monthly
Monthly exponential weighted moving average for current_ops, optimal_point_ops,
ewm_std_dev_monthly
ewm_std_dev.monthly
Monthly exponential weighted moving standard deviation based on one-minute
normalized_4k_current_ops
normalized_4k.current_ops
Total number of 4k current ops (normalized).
normalized_4k_optimal_point_ops
normalized_4k.optimal_point_ops
Total number of 4k optimal point ops (normalized).
observations_skipped
Number of observations not processed.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
