ONTAP 9.11.1 performance counter mapping
host_adapter
The host_adapter table reports activity on the Fibre Channel, Serial Attached SCSI, and parallel SCSI host adapters the storage system uses to connect to disks and tape drives.
Classic Object: hostadapter
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
total_reads
total_read_ops
Total number of reads on a host adapter
total_writes
total_write_ops
Total number of writes on a host adapter
bytes_read
bytes_read
Bytes read through a host adapter
bytes_written
bytes_written
Bytes written through a host adapter
max_link_data_rate
max_link_data_rate
Max link data rate in Kilobytes per second for a host adapter
rscn_count
rscn_count
Number of RSCN(s) received by the FC HBA
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
