ONTAP 9.11.1 performance counter mapping
iscsi_lif
CM table for exporting iSCSI LIF performance counters The alias names for iscsi_lif:svm and iscsi_lif:node are iscsi_lif_svm and iscsi_lif_node respectively.
Classic Object: iscsi_lif
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{svm.name}:{svm.uuid}
svm
This represents the construction of the row ID field in svm combo object, which is a single unique string that identifies a row.
{node.name}:{node.uuid}
node
This represents the construction of the row ID field in node combo object, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
instance_name
name
Name of this logical interface (LIF) row
instance_uuid
uuid
Unique ID of this logical interface (LIF) row
current_port
current_port
Name of the home port hosting the iSCSI logical interface (LIF)
vserver_name
svm.name
Name of the SVM owning this logical interface (LIF)
vserver_uuid
svm.uuid
UUID for the SVM owning this logical interface (LIF)
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
cmd_transferred
cmd_transferred
Command transferred by this iSCSI connection
iscsi_read_ops
iscsi_read_ops
iSCSI read operations per second on this logical interface (LIF)
iscsi_write_ops
iscsi_write_ops
iSCSI write operations per second on this logical interface (LIF)
iscsi_other_ops
iscsi_other_ops
iSCSI other operations per second on this logical interface (LIF)
total_ops
total_ops
iSCSI total operations per second on this logical interface (LIF)
scsi_cmd_rcvd
scsi_cmd_received
SCSI command received from iSCSI sessions on this logical interface (LIF)
nop_out_rcvd
nop_out_received
iSCSI nop_out command received from iSCSI sessions on this logical interface
(LIF)
taskmgmt_cmd_rcvd
taskmgmt_cmd_received
iSCSI task managment command received from iSCSI sessions on this logical
interface (LIF)
login_cmd_rcvd
login_cmd_received
iSCSI login command received from iSCSI sessions on this logical interface (LIF)
logout_cmd_rcvd
logout_cmd_received
iSCSI logout command received from iSCSI sessions on this logical interface
(LIF)
text_cmd_rcvd
text_cmd_received
iSCSI text command received from iSCSI sessions on this logical interface (LIF)
data_out_rcvd
data_out_received
iSCSI data_out Command received from iSCSI sessions on this logical interface
(LIF)
recv_data
received_data
Data received from iSCSI session on this logical interface (LIF)
snack_rcvd
snack_received
iSCSI snack received from iSCSI sessions on this logical interface (LIF)
unknown_pdu_rcvd
unknown_pdu_received
unknown iSCSI pdu received from iSCSI sessions on this logical interface (LIF)
scsi_resp_sent
scsi_response_sent
SCSI Command response sent from iSCSI sessions on this logical interface (LIF)
nop_in_sent
nop_in_sent
iSCSI nop_in response sent from iSCSI sessions on this logical interface (LIF)
taskmgmt_resp_sent
taskmgmt_response_sent
iSCSI task management response sent from iSCSI sessions on this logical
interface (LIF)
login_resp_sent
login_response_sent
iSCSI login response sent from iSCSI sessions on this logical interface (LIF)
logout_resp_sent
logout_response_sent
iSCSI logout response sent from iSCSI sessions on this logical interface (LIF)
text_resp_sent
text_response_sent
iSCSI text response sent from iSCSI sessions on this logical interface (LIF)
data_in_sent
data_in_sent
iSCSI data_in response sent from iSCSI sessions on this logical interface (LIF)
sent_data
sent_data
Data sent from iSCSI sessions on this logical interface (LIF)
r2t_sent
r2t_sent
iSCSI r2t sent from iSCSI sessions on this logical interface (LIF)
reject_sent
reject_sent
iSCSI reject sent from iSCSI sessions on this logical interface (LIF)
async_msg_sent
async_msg_sent
iSCSI asynchronous message sent from iSCSI sessions on this logical interface
(LIF)
data_in_blocks
data_in.blocks
Number of blocks sent from iSCSI sessions on this logical interface (LIF)
data_out_blocks
data_out.blocks
number of blocks received from iSCSI sessions on this logical interface (LIF)
read_data
read_data
Amount of data read from the storage system in bytes
write_data
write_data
Amount of data written to the storage system in bytes
total_data
total_data
Amount of data read/written from/to the storage system in bytes
recv_packet
received_packet
Packets(PDUs) received at the target side
sent_packet
sent_packet
Packets(PDUs) sent from the target side
recv_error
received_error
Errors received at the target side from initiator
error_status_cdb
error_status_cdb
Number of CDBs that contain error status from iSCSI sessions on this logical
interface (LIF)
success_status_cdb
success_status_cdb
Number of CDBs that contain success status from iSCSI sessions on this logical
interface (LIF)
login_failed
login_failed
Number of login failures from iSCSI sessions on this logical interface (LIF)
taskmgmt_failed
taskmgmt_failed
Number of task management failures from iSCSI sessions on this logical interface
(LIF)
logout_failed
logout_failed
Number of logout failures from iSCSI sessions on this logical interface (LIF)
text_cmd_failed
text_cmd_failed
Number of text command failures from iSCSI sessions on this logical interface
(LIF)
protocol_errors
protocol_errors
Number of protocol errors from iSCSI sessions on this logical interface (LIF)
header_digest_errors
Header digest errors from iSCSI sessions on this logical interface (LIF)
data_digest_errors
data_digest_errors
Data digest errors from iSCSI sessions on this logical interface (LIF)
outside_cmd_sn_win_pdus
outside_cmd_sequence_number_window_pdus
The PDUs that are out of command sequence number window from iSCSI sessions on
login_accept
login_accept
Number of logins accepted from iSCSI sessions on this logical interface (LIF)
login_itns
login_itns
Number of logins reported to SCSI-target for ITN creation
login_authentication_errors
Login authentication errors from iSCSI sessions on this logical interface (LIF)
login_authorization_errors
Login authorization errors from iSCSI sessions on this logical interface (LIF)
login_negotiation_errors
Login negotiation errors from iSCSI sessions on this logical interface (LIF)
login_other_errors
login_other_errors
Other login errors from iSCSI sessions on this logical interface (LIF)
login_redirect
login_redirect
Login redirects from iSCSI sessions on this logical interface (LIF)
logout_normals
logout_normals
Normal logouts from iSCSI sessions on this logical interface (LIF)
logout_others
logout_others
Other logouts from iSCSI sessions on this logical interface (LIF)
avg_read_latency
average_read_latency
Average latency for read operations
avg_write_latency
average_write_latency
Average latency for write operations
avg_other_latency
average_other_latency
Average latency for operations other than read and write (for example, Inquiry,
Report LUNs, SCSI Task Management Functions)
avg_latency
average_latency
Average latency for iSCSI operations
avg_login_latency
average_login_latency
Average latency for login completions
read_latency_hist
read_latency_histogram
Latency histogram for read operations
write_latency_hist
write_latency_histogram
Latency histogram for write operations
login_latency_hist
login_latency_histogram
Latency histogram for login completions
socket_latency_hist
socket_latency_histogram
Latency histogram for socket wait time receiving a full PDU
cmdproc_latency_hist
cmd_proc_latency_histogram
Latency histogram for command processing within iSCSI before SCSIT submit
cmdsub_latency_hist
cmd_sub_latency_histogram
Latency histogram for SCSIT command submit (from socket PDU recv)
do_pdu_latency_hist
data_out_pdu_latency_histogram
Latency histogram for a single DATA OUT PDU
do_scsit_latency_hist
data_out_scsit_latency_histogram
Latency histogram for time taken in SCSIT for DATA OUT
do_iscsi_latency_hist
data_out_iscsi_latency_histogram
Latency histogram for time taken in iSCSI after SCSIT callback
di_scsit_latency_hist
data_in_scsit_latency_histogram
Latency histogram for time taken in SCSIT for DATA IN
di_iscsi_latency_hist
data_in_iscsi_latency_histogram
diresp_latency_hist
data_in_response_latency_histogram
Latency histogram for Data IN SCSIT resp after SCSIT submit
outpdu_latency_hist
Latency histogram for out_pdu fully submitted to socket
doresp_latency_hist
data_out_response_latency_histogram
Latency histogram for Data OUT SCSIT response after SCSIT submit
read_size_hist
read_size_histogram
Histogram of read sizes
write_size_hist
write_size_histogram
Histogram of write sizes
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
Classic Object Alias
iscsi_lif:svm
iscsi_lif_svm
iscsi_lif:node
iscsi_lif_node
