ONTAP 9.11.1 performance counter mapping
object_store_client_op
CM table for exporting object store operation statistics. Object store operations are HTTP operations sent over TCP to manage objects on any object store.
Classic Object: object_store_client_op
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
stats
stats
Counter that indicates the number of object store operations sent, and their
success and failure counts for particular handle and particular object store
commands.
ops
ops
Counter that indicates the number of object store operations in total for
particular handle and particular object store commands. This counter acts as a
base counter for average_latency.
average_latency
average_latency
Average latencies executed during various phases of command execution. The
execution_start latency represents the average time taken to start executing an
operation. The request_prepare latency represents the average time taken to
prepare the complete request that needs to be sent to the server. The send
latency represents the average time taken to send requests to the server. The
execution_start_to_send_complete represents the average time taken to send a
request since its execution started. The execution_start_to_first_byte_received
latency represents the average time taken to receive the first byte of a
response since the command's execution started. These counters can be used to
identify performance bottlenecks within the object store client module. This
counter contains average latency for a particular handle and a particular object
store command.
throughput_bytes
throughput_bytes
Counter that indicates the throughput for the corresponding object store command
in bytes per second.
throughput_ops
throughput_ops
Counter that indicates the throughput for commands in operations per second.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
ops
The counter labels have changed. All of the dashes '-' in the labels were changed to underscores '_'.
average_latency
Table Aliases
This section describes aliases for aggregated tables.
