ONTAP 9.11.1 performance counter mapping
qos_detail
The qos_detail Counter Manager table that provides service center-based statistical information. Note: This table returns a very large number of instances. Querying by instance name and using wild cards may improve response times.
Classic Object: workload_detail
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
resource_name
resource.name
Name of the associated resource.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
visits
visits
The number of visits that the workload made to the service center; measured in
visits per second.
service_time
service_time
The workload's average service time per visit to the service center.
wait_time
wait_time
The workload's average wait time per visit to the service center.
in_latency_path
in_latency_path
Determines whether or not service center-based statistics are in the latency
path.
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
