ONTAP 9.11.1 performance counter mapping
svm_nfs_v3
The svm_nfs_v3 table reports activity for the Network File System protocol, version 3. This is the Sun file-sharing protocol that is predominant on UNIX platforms, used to connect to Network Attached Storage (NAS). The alias name for svm_nfs_v3:node is svm_nfs_v3_node.
Classic Object: nfsv3
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{node.name}:{instance_name}:{instance_uuid}
constituent
This represents the construction of a row ID field for a row from a single node.
{node.name}:{node.uuid}
node
This represents the construction of the row ID field in node combo object, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
Name of the node
instance_name
name
Constituent SVM name
vserver_id
svm.id
Vserver ID
vserver_name
svm.name
Name of SVM
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
null_success
null.success
Number of successful Null procedure requests. A null procedure does nothing. It
is used for testing and timing.
null_error
null.error
Number of erroneous Null procedure requests. A null procedure does nothing. It
null_total
null.total
Total number of Null procedure requests. It is the total of null success and
null error requests.
null_percent
null.percent
Percentage of Null procedure requests.
null_avg_latency
null.average_latency
Average latency of Null procedure requests.
getattr_success
getattr.success
Number of successful GetAttr procedure requests. The GetAttr procedure retrieves
the attributes for a specified file system object. Successful returns have a
NFS3_OK status.
getattr_error
getattr.error
Number of erroneous GetAttr procedure requests. The GetAttr procedure retrieves
getattr_total
getattr.total
Total number of Getattr procedure requests. It is the total number of getattr
success and getattr error requests.
getattr_percent
getattr.percent
Percentage of GetAttr procedure requests. This counter shows how often GetAttr
requests happen out of all NFSv3 requests.
getattr_avg_latency
getattr.average_latency
Average latency of GetAttr procedure requests. This counter keeps track of the
average response time of GetAttr requests.
setattr_success
setattr.success
Number of successful SetAttr procedure requests. The SetAttr procedure changes
one or more of the attributes of a file system object on the server.
setattr_error
setattr.error
Number of erroneous SetAttr procedure requests. The SetAttr procedure changes
setattr_total
setattr.total
Total number of Setattr procedure requests. It is the total number of Setattr
success and setattr error requests.
setattr_percent
setattr.percent
Percentage of Setattr procedure requests. The counter shows how often SetAttr
setattr_avg_latency
setattr.average_latency
Average latency of SetAttr procedure requests. The counter keeps track of the
average response time of SetAttr requests.
lookup_success
lookup.success
Number of successful LookUp procedure requests. The LookUp procedure searches a
directory for a specific name and returns the file handle for the corresponding
file system object.
lookup_error
lookup.error
Number of erroneous LookUp procedure requests. The LookUp procedure searches a
file system object.
lookup_total
lookup.total
Total number of Lookup procedure requests. It is the total number of lookup
success and lookup error requests.
lookup_percent
lookup.percent
Percentage of LookUp procedure requests. This counter shows how often LookUp
lookup_avg_latency
lookup.average_latency
Average latency of LookUp procedure requests. This shows the average time it
takes for the LookUp operation to reply to the request.
access_success
access.success
Number of successful Access procedure requests. The Access procedure determines
the access rights that a user has with respect to a file system object.
access_error
access.error
Number of erroneous Access procedure requests. The Access procedure determines
access_total
access.total
Total number of Access procedure requests. It is the total number of access
success and access error requests.
access_percent
access.percent
Percentage of Access procedure requests. This counter shows how often Access
access_avg_latency
access.average_latency
Average latency of Access procedure requests. The counter keeps track of the
average response time of Access requests.
read_symlink_success
read_symlink.success
Number of successful ReadSymlink procedure requests. The ReadSymLink procedure
reads the data associated with a symbolic link. A symbolic link is a file system
object that points to another file system object.
read_symlink_error
read_symlink.error
Number of erroneous ReadSymlink procedure requests. The ReadSymLink procedure
read_symlink_total
read_symlink.total
Total number of ReadSymLink procedure requests. It is the total number of read
symlink success and read symlink error requests.
read_symlink_percent
read_symlink.percent
Percentage of ReadSymLink procedure requests. This counter shows how often
ReadSymLink requests happen out of all NFSv3 requests.
read_symlink_avg_latency
read_symlink.average_latency
Average latency of ReadSymLink procedure requests. The counter keeps track of
the average response time of ReadSymLink requests.
read_success
read.success
Number of successful Read procedure requests. The Read procedure reads data from
a file.
read_error
read.error
Number of erroneous Read procedure requests. The Read procedure reads data from
a file.
read_total
read.total
Total number Read of procedure requests. It is the total number of read success
and read error requests.
read_percent
read.percent
Percentage of Read procedure requests. This counter shows how often Read
read_avg_latency
read.average_latency
Average latency of Read procedure requests. The counter keeps track of the
average response time of Read requests.
write_success
write.success
Number of successful Write procedure requests. The Write procedure writes data
to a file.
write_error
write.error
Number of erroneous Write procedure requests. The Write procedure writes data to
a file.
write_total
write.total
Total number of Write procedure requests. It is the total number of write
success and write error requests.
write_percent
write.percent
Percentage of Write procedure requests. This counter shows how often Write
write_avg_latency
write.average_latency
Average latency of Write procedure requests. The counter keeps track of the
average response time of Write requests.
create_success
create.success
Number of successful Create procedure requests. The Create procedure creates a
regular file.
create_error
create.error
Number of erroneous Create procedure requests. The Create procedure creates a
regular file.
create_total
create.total
Total number Create of procedure requests. It is the total number of create
success and create error requests.
create_percent
create.percent
Percentage of Create procedure requests. This counter shows how often Create
create_avg_latency
create.average_latency
Average latency of Create procedure requests. The counter keeps track of the
average response time of Create requests.
mkdir_success
mkdir.success
Number of successful MkDir procedure requests. The MkDir procedure creates a new
subdirectory.
mkdir_error
mkdir.error
Number of erroneous MkDir procedure requests. The MkDir procedure creates a new
subdirectory.
mkdir_total
mkdir.total
Total number MkDir of procedure requests. It is the total number of MkDir
success and MkDir error requests.
mkdir_percent
mkdir.percent
Percentage of MkDir procedure requests. This counter shows how often MkDir
mkdir_avg_latency
mkdir.average_latency
Average latency of MkDir procedure requests. The counter keeps track of the
average response time of MkDir requests.
symlink_success
symlink.success
Number of successful SymLink procedure requests. The SymLink procedure creates a
symbolic link. A symbolic link is a file system object that points to another
file system object.
symlink_error
symlink.error
Number of erroneous SymLink procedure requests. The SymLink procedure creates a
file system object.
symlink_total
symlink.total
Total number SymLink of procedure requests. It is the total number of SymLink
success and create SymLink requests.
symlink_percent
symlink.percent
Percentage of Symlink procedure requests. This counter shows how often Symlink
symlink_avg_latency
Average latency of SymLink procedure requests. The counter keeps track of the
average response time of SymLink requests.
mknod_success
mknod.success
Number of successful MkNod procedure requests. The MkNod procedure creates a
special file that can be device files or named pipes.
mknod_error
mknod.error
Number of erroneous MkNod procedure requests. The MkNod procedure creates a
mknod_total
mknod.total
Total number MkNod of procedure requests. It is the total number of MkNod
success and MkNod error requests.
mknod_percent
mknod.percent
Percentage of MkNod procedure requests. This counter shows how often MkNod
mknod_avg_latency
mknod.average_latency
Average latency of MkNod procedure requests. The counter keeps track of the
average response time of MkNod requests.
remove_success
remove.success
Number of successful Remove procedure requests. The Remove procedure deletes an
entry from a directory.
remove_error
remove.error
Number of erroneous Remove procedure requests. The Remove procedure deletes an
remove_total
remove.total
Total number Remove of procedure requests. It is the total number of Remove
success and Remove error requests.
remove_percent
remove.percent
Percentage of Remove procedure requests. This counter shows how often Remove
remove_avg_latency
remove.average_latency
Average latency of Remove procedure requests. The counter keeps track of the
average response time of Remove requests.
rmdir_success
rmdir.success
Number of successful RmDir procedure requests. The RmDir procedure deletes a
subdirectory from a directory.
rmdir_error
rmdir.error
Number of erroneous RmDir procedure requests. The RmDir procedure deletes a
rmdir_total
rmdir.total
Total number RmDir of procedure requests. It is the total number of RmDir
success and RmDir error requests.
rmdir_percent
rmdir.percent
Percentage of RmDir procedure requests. This counter shows how often RmDir
rmdir_avg_latency
rmdir.average_latency
Average latency of RmDir procedure requests. The counter keeps track of the
average response time of RmDir requests.
rename_success
rename.success
Number of successful Rename procedure requests. The Rename procedure renames the
file.
rename_error
rename.error
Number of erroneous Rename procedure requests. The Rename procedure renames the
file.
rename_total
rename.total
Total number Rename of procedure requests. It is the total number of Rename
success and Rename error requests.
rename_percent
rename.percent
Percentage of Rename procedure requests. This counter shows how often Rename
rename_avg_latency
rename.average_latency
Average latency of Rename procedure requests. The counter keeps track of the
average response time of Rename requests.
link_success
link.success
Number of successful Link procedure requests. The Link procedure creates a hard
link. A hard link is a directory entry that associates a name with a file on a
file system.
link_error
link.error
Number of erroneous Link procedure requests. The Link procedure creates a hard
file system.
link_total
link.total
Total number Link of procedure requests. It is the total number of Link success
and Link error requests.
link_percent
link.percent
Percentage of Link procedure requests. This counter shows how often Link
link_avg_latency
Average latency of Link procedure requests. The counter keeps track of the
average response time of Link requests.
readdir_success
readdir.success
Number of successful ReadDir procedure requests. The ReadDir retrieves a
variable number of entries from a directory and returns the name of file
identifier for each.
readdir_error
readdir.error
Number of erroneous ReadDir procedure requests. The ReadDir retrieves a variable
number of entries from a directory and returns the name of file identifier for
each.
readdir_total
readdir.total
Total number ReadDir of procedure requests. It is the total number of ReadDir
success and ReadDir error requests.
readdir_percent
readdir.percent
Percentage of ReadDir procedure requests. This counter shows how often ReadDir
readdir_avg_latency
readdir.average_latency
Average latency of ReadDir procedure requests. The counter keeps track of the
average response time of ReadDir requests.
readdirplus_success
readdirplus.success
Number of successful ReadDirPlus procedure requests. The ReadDirPlus retrieves a
variable number of entries from a file system directory and returns complete
information about each.
readdirplus_error
readdirplus.error
Number of erroneous ReadDirPlus procedure requests. The ReadDirPlus retrieves a
readdirplus_total
readdirplus.total
Total number ReadDirPlus of procedure requests. It is the total number of
ReadDirPlus success and ReadDirPlus error requests.
readdirplus_percent
readdirplus.percent
Percentage of ReadDirPlus procedure requests. This counter shows how often
ReadDirPlus requests happen out of all NFSv3 requests.
readdirplus_avg_latency
readdirplus.average_latency
Average latency of ReadDirPlus procedure requests. The counter keeps track of
the average response time of ReadDirPlus requests.
fsstat_success
fsstat.success
Number of successful FsStat procedure requests. The FsStat procedure retrieves
volatile file system state information.
fsstat_error
fsstat.error
Number of erroneous FsStat procedure requests. The FsStat procedure retrieves
fsstat_total
fsstat.total
Total number FSStat of procedure requests. It is the total number of FSStat
success and FSStat error requests.
fsstat_percent
fsstat.percent
Percentage of FSStat procedure requests. This counter shows how often FSStat
fsstat_avg_latency
fsstat.average_latency
Average latency of FSStat procedure requests. The counter keeps track of the
average response time of FSStat requests.
fsinfo_success
fsinfo.success
Number of successful FsInfo procedure requests. The FsInfo procedure retrieves
nonvolatile file system state information and provides general information about
the NFS version 3 protocol server implementation
fsinfo_error
fsinfo.error
Number of erroneous FsInfo procedure requests. The FsInfo procedure retrieves
fsinfo_total
fsinfo.total
Total number FSInfo of procedure requests. It is the total number of FSInfo
success and FSInfo error requests.
fsinfo_percent
fsinfo.percent
Percentage of FsInfo procedure requests. This counter shows how often FsInfo
fsinfo_avg_latency
fsinfo.average_latency
Average latency of FSInfo procedure requests. The counter keeps track of the
average response time of FSInfo requests.
pathconf_success
pathconf.success
Number of successful PathConf procedure requests. The PathConf retrieves the
pathconf information for a file or directory.
pathconf_error
pathconf.error
Number of erroneous PathConf procedure requests. The PathConf retrieves the
pathconf_total
pathconf.total
Total number PathConf of procedure requests. It is the total number of PathConf
success and PathConf error requests.
pathconf_percent
pathconf.percent
Percentage of PathConf procedure requests. This counter shows how often PathConf
pathconf_avg_latency
pathconf.average_latency
Average latency of PathConf procedure requests. The counter keeps track of the
average response time of PathConf requests.
commit_success
commit.success
Number of successful Commit procedure requests. The Commit procedure forces or
flushes data to stable storage that was previously written with a Write
procedure call with stable field set to UNSTABLE.
commit_error
commit.error
Number of erroneous Commit procedure requests. The Commit procedure forces or
commit_total
commit.total
Total number of Commit procedure requests. It is the total number of Commit
success and Commit error requests.
commit_percent
commit.percent
Percentage of Commit procedure requests. This counter shows how often Commit
commit_avg_latency
commit.average_latency
Average latency of Commit procedure requests. The counter keeps track of the
average response time of Commit requests.
nfsv3_ops
ops
Total number of NFSv3 procedure requests per second.
null_latency_hist
null_latency_histogram
Histogram of latency for Null operations.
getattr_latency_hist
getattr_latency_histogram
Histogram of latency for Getattr operations.
setattr_latency_hist
setattr_latency_histogram
Histogram of latency for Setattr operations.
lookup_latency_hist
lookup_latency_histogram
Histogram of latency for LookUp operations.
access_latency_hist
access_latency_histogram
Histogram of latency for Access operations.
readlink_latency_hist
readlink_latency_histogram
Histogram of latency for ReadLink operations.
read_latency_hist
read_latency_histogram
Histogram of latency for Read operations.
write_latency_hist
write_latency_histogram
Histogram of latency for Write operations.
create_latency_hist
create_latency_histogram
Histogram of latency for Create operations.
mkdir_latency_hist
mkdir_latency_histogram
Histogram of latency for Mkdir operations.
symlink_latency_hist
symlink_latency_histogram
Histogram of latency for SymLink operations.
mknod_latency_hist
mknod_latency_histogram
Histogram of latency for Mknod operations.
remove_latency_hist
remove_latency_histogram
Histogram of latency for Remove operations.
rmdir_latency_hist
rmdir_latency_histogram
Histogram of latency for Rmdir operations.
rename_latency_hist
rename_latency_histogram
Histogram of latency for Rename operations.
link_latency_hist
Histogram of latency for Link operations.
readdir_latency_hist
readdir_latency_histogram
Histogram of latency for Readdir operations.
readdirplus_latency_hist
readdir_plus_latency_histogram
Histogram of latency for Readdirplus operations.
fsstat_latency_hist
fsstat_latency_histogram
Histogram of latency for Fsstat operations.
fsinfo_latency_hist
fsinfo_latency_histogram
Histogram of latency for Fsinfo operations.
pathconf_latency_hist
pathconf_latency_histogram
Histogram of latency for Pathconf operations.
comit_latency_hist
commit_latency_histogram
Histogram of latency for Commit operations.
nfsv3_latency_hist
latency_histogram
Histogram of latency for NFSv3 operations.
nfsv3_read_size_histo
read_size_histogram
Histogram of NFSv3 Read size.
nfsv3_write_size_histo
write_size_histogram
Histogram of NFSv3 Write size.
nfsv3_read_throughput
read_throughput
Rate of NFSv3 read data transfers per second.
nfsv3_write_throughput
write_throughput
Rate of NFSv3 write data transfers per second.
nfsv3_throughput
throughput
Rate of NFSv3 data transfers per second.
nfsv3_dnfs_ops
oracle_direct_nfs_ops
Rate of NFSv3 operations per second served to clients utilizing Oracle Direct
NFS
nfsv3_hadoop_ops
hadoop_ops
Rate of NFSv3 operations per second served to clients utilizing Hadoop NFS
readdir_postop_error
readdir.postop_error
Number of failed Postop ReadDir procedures. Postop ReadDir errors are failures
in the response of the request.
readdirplus_postop_error
readdirplus.postop_error
Number of failed Postop ReadDirPlus procedures. Postop ReadDirPlus errors are
failures in the response of the request.
raidprop_error
raid_error
Number of times RAID errors encountered in NFSv3 path.
nfsv3_read_ops
read_ops
Total observed NFSv3 read operations per second.
nfsv3_write_ops
write_ops
Total observed NFSv3 write operations per second.
latency
latency
Average latency of NFSv3 requests. This counter keeps track of the average
response time of NFSv3 requests.
nfsv3_fileop_max_latency
fileop_max_latency
Maximum latency of NFSv3 requests. This counter keeps track of the maximum
response time of NFSv3 requests at any point in time.
total_ops
total_ops
Total number of NFSv3 requests per sec
free_pass_ops
free_pass_ops
This counter keeps track of the number of NFSv3 requests which have asked to
bypass COP HWM
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
Classic Object Alias
svm_nfs_v3:node
svm_nfs_v3_node
