ONTAP 9.11.1 performance counter mapping
wafl_hya_sizer
This table is for exporting Automated Working-set Analyzer (AWA) statistics. AWA is an ONTAP capability that estimates the Flash Pool cache size and estimates the cache hit rates across reads and writes. Detailed statistic values of an AWA instance enabled on a specific aggregate are available here.
Classic Object: wafl_hya_sizer
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
aggr_name
aggregate.name
Name of the aggregate.
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
version
version
Automated Working-set Analyzer (AWA) version.
start_time
start_time
Start time in milliseconds.
current_time
current_time
Current time based on ONTAP internal clock in milliseconds (sk_msecs).
start_cp_count
start_cp_count
CP (Consistency Point) count when the sizer is enabled.
rstart_time
relative_start_time
Relative start time of the scoped interval in milliseconds.
rstart_cp_count
relative_start_cp_count
CP (Consistency Point) count when the sizer is started relative to the beginning
of scoped intervals.
total_intervals
total_intervals
Total number of intervals since the sizer was enabled including the current one.
overwrite_cp_delta
overwrite_cp_delta
The histogram of CP (Consistency Point) count delta between overwrites.
hash_max_unique
hash_max_unique
Aggregate space max_unique for hashing.
hash_sampling_factor
Aggregate space hash sampling factor.
target_pcache_mb
target_pcache_mb
Configured target pseudo cache memory in megabytes.
pcache_mem
pcache_memory
Derived memory size during configuration.
target_sampling_factor
Configured target sampling factor.
derived_sampling_factor
Derived sampling factor.
pcache_no_of_entries
pcache_number_of_entries
Derived number of pseudo cache entries which is the same as the number of cached
blocks.
incore_intervals
incore_intervals
Total incore intervals.
interval_msec
interval_msec
Interval length in milliseconds.
num_disks
number_disks
Number of disks.
sync_with_stats_zero
If the value is one, the Automated Working-set Analyzer (AWA) interval resets
when wafl statistics are reset (by wafl_stats_zero command).
enable_rc_after_write
If the value is one, the option of Read-cache After Write is enabled.
vvol_stats
vvol_stats
Collect per-volume statistics.
debug_level
debug_level
Debug Level.
scope_interval
scope_interval
Number of intervals of the sliding window scope.
scope_phaseout
scope_phase_out
If the value is 1, AWA phases out old accumulations from the histograms.
cache_mode
cache_mode
Automated Working-set Analyzer (AWA) cache mode: normal, read-cache only, write-
cache only, always cache.
interval_info
interval_info
Interval Information.
lookup_type_mismatch
Number of type mismatches when lookup finds an entry.
entry_matched
entry_matched
Number of pseudo cache entry lookup attempts. For random-hash-sampled cases,
this is the number of lookup/insert attempts. For statically sampled case, this
is the number of lookups that falls into sampled disks.
entry_sampled
entry_sampled
Number of pseudo cache hashed Volume Block Number (VBN) sampled based on
sampling factor.
wc_flagged
wc_flagged
Number of buffers flagged for write-caching after check for random write at
buffer-dirty time.
can_wc_dirty
can_wc_dirty
Number of buffers that can be write-cached at write-allocation time.
cant_wc_dirty
cant_wc_dirty
Number of buffers that cannot be write-cached at write-allocation time.
wc_overwrite
wc_overwrite
Number of write-cached blocks being overwritten.
long_chain
long_chain
Number of reads with buffer count long enough to go to hard disk drives (HDD)
directly.
wc_ins_for_destage
wc_ins_for_destage
Number of Automated Working-set Analyzer (AWA) write-cached block inserts for
actual destages on a Flash Pool aggregate.
rc_after_write
rc_after_write
Number of buffers flagged for read cache after write.
cache_rej_reason_dist_FP
cache_reject_reason_dist_fp
Automated Working-set Analyzer (AWA) pseudo cache insert reject reason
distribution for Floating Point (FP) cache inserts. This array is a table with
fields corresponding to the reject reasons defined by enum type
hya_cache_rej_reasons_t.
distribution not for FP aggregate cache inserts. This array is a table with
aggrwide_regular_stats
aggregate_wide_regular_stats
Automated Working-set Analyzer (AWA) aggregate-wide regular statistics for the
most recent number of intervals. The number of intervals that are considered
recent is defined by CM_WAFL_HYAS_INT_DIS_CNT. This array is a table with fields
corresponding to the enum type hya_regular_stat_type_t.
aggrwide_cache_stats
aggregate_wide_cache_stats
Automated Working-set Analyzer (AWA) aggregate-wide cache statistics for the
most recent number of intervals. The number of intervals that are considered as
recent is defined as CM_WAFL_HYAS_INT_DIS_CNT. This array is a table with fields
corresponding to enum type hyas_cache_stat_type_t.
aggrwide_cache_interarrival_stats
aggregate_wide_cache_interarrival_stats
Automated Working-set Analyzer (AWA) aggregate-wide interarrival distribution
for intervals up to CM_WAFL_HYAS_INT_DIS_CNT. This array is a table with fields
corresponding to the enum type of hya_cache_ia_stat_type_t.
regular_stats
regular_stats
Automated Working-set Analyzer (AWA) per-interval regular statistics for the
most recent number of intervals. The number of intervals defined as recent is
CM_WAFL_HYAS_INT_DIS_CNT. This array is a table with fields corresponding to the
enum type of hyas_regular_stat_type_t.
cache_stats
cache_stats
Automated Working-set Analyzer (AWA) per-interval pseudo cache statistics for
the most recent intervals. The number of intervals defined as recent is
enum type of hyas_cache_stat_type_t.
Automated Working-set Analyzer (AWA) pseudo cache interarrival distribution for
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
The labels have changed from "Free overwrite" to "free_overwrite".
The labels have changed from "rd_rc_L0_interval" to "rd_rc_l0_interval".
regular_stats
cache_stats
Table Aliases
This section describes aliases for aggregated tables.
