ONTAP 9.12.1 performance counter mapping
fcp_lif
An FCP LIF is a logical interface that connects a SVM to a physical FCP port. This table collects diagnostics and performance information for an FCP LIF. The table counters can be used to debug and diagnose connectivity issues with initiators or fabric on a LIF. The table counters can be used to debug and diagnose connectivity issues with initiators or fabric at a LIF level granularity. The alias names for fcp_lif:svm and fcp_lif:port are fcp_lif_svm and fcp_lif_port respectively.
Classic Object: fcp_lif
Table Row IDs
ID Format Aggregation Type Comment
{instance_name}:{instance_uuid}
(not applicable)
This represents the construction of the row ID field, which is a single unique string that identifies a row.
{svm.name}:{svm.uuid}
svm
This represents the construction of the row ID field in svm combo object, which is a single unique string that identifies a row.
{port.id}:{port.wwpn}
port
This represents the construction of the row ID field in port combo object, which is a single unique string that identifies a row.
{node.name}:{node.uuid}
node
This represents the construction of the row ID field in node combo object, which is a single unique string that identifies a row.
Properties
This section describes the mapping between classic (ONTAPI) string counter names and REST property names.
Classic String Counter REST Property Description
node_name
node.name
System node name
instance_name
name
Name of this logical interface (LIF)
instance_uuid
unique_id
Unique id of this logical interface (LIF)
vserver_name
svm.name
Name of the SVM that owns this logical interface (LIF)
vserver_uuid
svm.uuid
UUID of the SVM that owns this logical interface (LIF)
port_wwpn
port.wwpn
WWPN for the port
port_id
port.id
ID for the port
Counters
This section describes the mapping between classic (ONTAPI) numeric counter names and REST counter names.
Classic Numeric Counter REST Counter Description
read_ops
read_ops
Number of read operations
write_ops
write_ops
Number of write operations
other_ops
other_ops
Number of operations that are not read or write.
total_ops
total_ops
Total number of operations.
read_data
read_data
Amount of data read from the storage system
write_data
write_data
Amount of data written to the storage system
total_data
total_data
Amount of FCP traffic to and from the storage system
ls_reject
link_service_reject
Number of link service (LS) requests rejected.
command_sequence_error
command.sequence_error
Number of sequence errors seen for ELS/CT commands
command_sequence_timeout
command.sequence_timeout
Number of sequence timeouts seen for ELS/CT commands
command_terminate
command.terminate
Number of terminate requests processed for IO commands
total_logins
total_logins
Total number of logins
total_logouts
total_logouts
Total number of logouts
inits_connected
initiators_connected
Number of initiators that are currently logged in to the logical interface (LIF)
portlogout_disc_timeout
port_logout_disc.timeout
Number of port logouts caused by discovery (DISC) timeouts
portlogout_disc_rjt
port_logout_disc.reject
Number of port logouts caused by rejected discovery (DISC) frames
login_affecting_prli
login_affecting.process_login
Number of login-affecting process login (PRLI) frames received
login_affecting_prlo
login_affecting.process_logout
Number of login-affecting process logout (PRLO) frames received
login_affecting_plogi
login_affecting.port_login
Number of port login (PLOGI) frames received
login_affecting_logo
login_affecting.logout
Number of logout (LOGO) frames received
login_affecting_tprlo
login_affecting.third_party_logout
Number of login-affecting third-party logouts (TPRLOs) received
avg_read_latency
average_read_latency
Average latency for read operations
avg_write_latency
average_write_latency
Average latency for write operations
avg_other_latency
average_other_latency
Average latency for operations other than read and write
avg_latency
average_latency
Average latency for FCP operations
read_latency_hist
read_latency_histogram
Latency histogram for read operations
read_cmd_data_proc_latency_hist_8K
read_cmd_data_proc.latency_histogram_8K
Histogram for read command processing and data delivery time for I/O less
than/equal to 8K
read_cmd_data_proc_latency_hist_16K
read_cmd_data_proc.latency_histogram_16K
Histogram for read command processing and data delivery time for I/O greater
than 8K AND less than/equal to 16K
read_cmd_data_proc_latency_hist_32K
read_cmd_data_proc.latency_histogram_32K
than 16K AND less than/equal to 32K
read_cmd_data_proc_latency_hist_64K
read_cmd_data_proc.latency_histogram_64K
than 32K AND less than/equal to 64K
read_cmd_data_proc_latency_hist_large_IO
read_cmd_data_proc.latency_histogram_large_io
than 64K
write_latency_hist
write_latency_histogram
Latency histogram for write operations
write_cmd_proc_latency_hist_8K
write_cmd_proc.latency_histogram_8K
Histogram for write command processing time for I/O less than/equal to 8K
write_cmd_proc_latency_hist_16K
write_cmd_proc.latency_histogram_16K
Histogram for write command processing time for I/O greater than 8K AND less
than/equal to 16K
write_cmd_proc_latency_hist_32K
write_cmd_proc.latency_histogram_32K
Histogram for write command processing time for I/O greater than 16K AND less
than/equal to 32K
write_cmd_proc_latency_hist_64K
write_cmd_proc.latency_histogram_64K
Histogram for write command processing time for I/O greater than 32K AND less
than/equal to 64K
write_cmd_proc_latency_hist_large_IO
write_cmd_proc.latency_histogram_large_io
Histogram for write command processing time for I/O greater than 64K
write_data_consume_latency_hist_8K
write_data_consume.latency_histogram_8K
Histogram for write data consumption time for I/O less than/equal to 8K
write_data_consume_latency_hist_16K
write_data_consume.latency_histogram_16K
Histogram for write data consumption time for I/O greater than 8K AND less
than/equal to 16K
write_data_consume_latency_hist_32K
write_data_consume.latency_histogram_32K
Histogram for write data consumption time for I/O greater than 16K AND less
than/equal to 32K
write_data_consume_latency_hist_64K
write_data_consume.latency_histogram_64K
Histogram for write data consumption time for I/O greater than 32K AND less
than/equal to 64K
write_data_consume_latency_hist_large_IO
write_data_consume.latency_histogram_large_io
Histogram for write data consumption time for I/O greater than 64K
read_size_hist
read_size_histogram
Histogram of read sizes
write_size_hist
write_size_histogram
Histogram of write sizes
request_dropped_no_map
request_dropped.no_map
Number of requests dropped because of no valid initiator target nexus (ITN).
request_dropped_no_resource
request_dropped.no_resource
Number of requests dropped because of lack of driver resources.
request_dropped_no_hw_resource
request_dropped.no_hw_resource
Number of requests dropped because of lack of hardware resources.
request_dropped_no_exch_resource
request_dropped.no_exchange_resource
Number of requests dropped because of lack of exchange resources in the
firmware.
request_taskfull_no_exch_resource
request_taskfull.no_exchange_resource
Number of requests responded with a taskfull because of lack of exchange
resources in the firmware.
request_dropped_not_ready
request_dropped.not_ready
Number of requests dropped because the LIF is not ready.
els_plogi_error
els.port_login_error
Number of times an error was encountered when processing a port login (PLOGI)
command
els_flogi_error
els.fabric_login_error
Number of times an error was encountered when processing a fabric login (FLOGI)
command
els_fdisc_error
els.fabric_discovery_error
Number of times an error was encountered when processing a fabric discovery
(FDISC) command
els_logo_error
els.logout_error
Number of times an error was encountered when processing a logout (LOGO) command
els_echo_error
els.echo_error
Number of times an error was encountered when processing an ECHO command
els_scr_error
els.state_change_register_error
Number of times an error was encountered when processing a state change
registration (SCR) command
els_acc_error
els.accept_error
Number of times an error was encountered when processing an ELS ACCEPT command
els_edc_error
els.exchange_diag_capability_error
Number of times an error was encountered while processing an Exchange Diagnostic
Capabilities (EDC) command
els_rdf_error
els.register_diag_func_error
Number of times an error was encountered while processing a Register Diagnostic
Functions (RDF) command
ct_gppn_error
ct.get_physical_port_num_error
Number of times an error was encountered while processing a get physical port
number (GPPN) command
ct_giel_error
ct.get_interconnect_element_list_error
Number of times an error was encountered while processing a get interconnect
element list (GIEL) command
ct_gdid_error
ct.get_domain_id_error
Number of times an error was encountered while processing a get domain
identifier (GDID) command
ct_gpl_error
ct.get_port_list_error
Number of times an error was encountered while processing a get port list (GPL)
command
ct_gieln_error
ct.get_interconnect_element_logical_name_error
element logical name (GIELN) command
ct_gieil_error
ct.get_interconnect_element_info_list_error
element information list (GIEIL) command
ct_gapnl_error
ct.get_attached_port_name_list_error
Number of times an error was encountered while processing a get attached port
name list (GAPNL) command
ct_gps_error
ct.get_port_state_error
Number of times an error was encountered while processing a get port state (GPS)
command
ct_gfn_error
ct.get_fabric_name_error
Number of times an error was encountered while processing a get fabric name
(GFN) command
ct_gfpn_id_error
ct.get_fabric_port_name_id_error
Number of times an error was encountered while processing a get fabric port name
(GFPN) command
ct_ga_nxt_error
ct.get_all_next_error
Number of times an error was encountered while processing a get all next
(GA_NXT) command
ct_gid_pn_error
ct.get_id_port_num_error
Number of times an error was encountered while processing a get port identifier
(GID_PN) command
ct_gpn_id_error
ct.get_port_name_id_error
Number of times an error was encountered while processing a get port name
(GPN_ID) command
ct_gid_pt_error
ct.get_id_port_error
Number of times an error was encountered while processing a get port identifiers
(GID_PT) command
ct_rft_id_error
ct.register_fc_type_id_error
Number of times an error was encountered while processing a register FC-4 types
(RFT_ID) command
ct_rff_id_error
ct.register_fc_feature_id_error
features (RFF_ID) command
ct_rspn_id_error
ct.register_sym_port_name_id_error
Number of times an error was encountered while processing a register symbolic
port name (RSPN_ID) command
ct_rsnn_nn_error
ct.register_sym_node_name_error
node name (RSNN_NN) command
ct_gazs_error
ct.get_active_zone_set_error
Number of times an error was encountered while processing a get active zone set
(GAZS) command
ct_gfez_error
ct.get_fabric_enh_zone_error
Number of times an error was encountered while processing a get fabric enhanced
zoning (GFEZ) command
ct_sfez_error
ct.set_fabric_enh_zone_error
Number of times an error was encountered while processing a set fabric enhanced
zoning (SFEZ) command
abts_completed
abts.completed
Number of ABTS successfully completed by the driver
abts_drop_cmd_not_found
abts.drop_cmd_not_found
Number of ABTS frames dropped because no associated command was found
abts_drop_itn_not_ready
abts.drop_initiator_target_nexus_not_ready
Number of ABTS frames dropped because no associated ITN was found
abts_drop_no_resource
abts.drop_no_resource
Number of ABTS frames dropped because there were no resources available for
processing
abts_nvme_fc_spdk_master_enqueue_failure
abts.nvme_fc_spdk_master_enqueue_failure
Number of NVMe/FC ABTS events that failed to be enqueued to spdk for processing
abts_nvme_fc_spdk_master_enqueue_success
abts.nvme_fc_spdk_master_enqueue_success
Number of NVMe/FC ABTS events successfully enqueued to spdk for processing
gs_cmd_retry
gs_cmd_retry
Number of FC-GS commands that were retried
ct_pz_rscn_success
ct.peer_zone_rscn_success
Successful RSCNs initiated due to FC Peer Zone changes
ct_gapz_error
ct.get_active_peer_zone_error
Errors encountered while processing a Get Active Peer Zone (GAPZ) command
ct_aapz_error
ct.add_replace_active_peer_zone_error
Errors encountered while processing an Add/Replace Active Peer Zone (AAPZ)
command
ct_rapz_error
ct.remove_active_peer_zone_error
Errors encountered while processing a Remove Active Peer Zone (RAPZ) command
Property/Counter Content Changes
This section describes any output value differences between the classic (ONTAPI) string counter and the respective REST property. It also describes array label name changes between classic array counters and respective REST array counters.
Table Aliases
This section describes aliases for aggregated tables.
Classic Object Alias
fcp_lif:svm
fcp_lif_svm
fcp_lif:port
fcp_lif_port
